ā08-17-2015 04:16 AM - edited ā03-18-2019 04:52 AM
i have sx20 device , set up and configuration completed , able make/recieved calls . but a message showing on display Not register , how to get rid of this
ā08-17-2015 05:22 AM
Let me move this post to Telepresence community as this community is not observed by TP experts. This community is for Cisco Unified MeetingPlace and Cisco WebEx Meetings Server products.
I hope this will get you the answer you need faster.
Kind regards,
-Dejan
ā08-17-2015 05:34 AM
thanks
ā08-17-2015 01:20 PM
Are you using IP to IP dialing method?
Normally the system will show the error message if your SX20 endpoint is not properly configured to use H323 gatekeeper/SIP proxy registration.
To get rid of the error message, turn off any SIP or H323 configuration on your SX20 if not required.
Then you can change and choose which type of contact information to show in the status field in the upper left corner of the main display and Touch Panel (IP address/System Name).
Under Configuration go to System Configuration > SystemUnit > SystemUnit ContactInfo Type.
Acevirgil
ā08-25-2015 06:05 AM
thanks, i will check
ā11-26-2015 04:27 AM
Dear support0219 how are you?
I am newer on Cisco Telepresence, and I have the same issue.
Did you have the solution for this?
Please sare with me
Best Regards
Alcidio Tembe
