SIP Gateway to PSTN config?
sardarzandieh
Hi Everyone
I currently have a h323 gateway which is connected to PSTN via  a PRI.
because of cost savings , we are canceling the PRIs and getting a SIP trunk.
how do i go about configuring the SIP trunk into the IOS to conenct to PSTN?
anyone has any sample configs that i can take a look at?
for the H323 and PRI, i always have the Serial interface with the ESF and B8ZS and so on.
how do i go about configuring the SIP for PSTN access?
any help is greatly appricaited.
hrnaqvi12
You need an IOS of IP to IP Gateway for your router.
You just need to configure and allow connection of sip to h323 and vice versa in , " voice service voip " , and configure inbount/outbound dial peers.
Scott Brien
You will need an IP-IP gateway as stated above
Please see below sample configuration which i beleive to be relevant to your situation
voice service voip
media flow-around
allow-connections h323 to sip
allow-connections sip to h323
voice class codec 99
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
  call preserve
sccp local GigabitEthernet0/0
sccp ccm X.X.X.X identifier 2 version 7.0
sccp ccm X.X.X.X identifier 1 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register XCODE
associate profile 1 register MTP
dspfarm profile 1 mtp
codec g711ulaw
maximum sessions software 100
associate application SCCP
dial-peer voice 2 voip
description *INBOUND FROM SP*
media flow-around
session protocol sipv2
incoming called-number .
voice-class sip asserted-id pai
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 10 voip ** Outbound dial-peer to SIP Trunk
description -- Outbound to SP
translation-profile outgoing egressTranslation
destination-pattern 0T
session target ipv4:X.X.X.X
codec g711ulaw
voice-class sip asymmetric payload dynamic-codecs
voice-class sip early-offer forced
voice-class sip error-code-override options-keepalive failure 500
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip ** customers DiD range to IPPBX
destination-pattern XXXXXXXXXX
media flow-around
codec g711ulaw
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
This is a cutdown version of an IP-IP gateway however i hope it to be a good starting point for you.
Scott
Thanks for hte Help Scott
Sorry for the late response.
