Supporting Nortel Remote Shelf with VOIP
jrhofman
Does anyone have any experience using H.323 gateways for supporting a Nortel remote shelf to headend PBX across a WAN.
The connection requires a clear channel t1 trunk between shelf and PBX. This is a bit different I think than trunking between PBXs.
Can this be set up with standard Voice PRI/T1 modules in H.323 gateways?
Any insights would be helpful
rlbrumm
Yes it can.. However, the programming on the router for the clear channel trunk is extensive. What is the gateway?
I have three clear channels trunks between a Nortel Opt81 through a 7206 router at one end going to a 3745 to an Option 11 at the remote end.
Try this link:
http://www.cisco.com/en/US/customer/tech/tk652/tk653/technologies_tech_note09186a00800a96c1.shtml#tccctopic
