11-29-2017 08:06 AM - edited 03-18-2019 01:39 PM
One of our SX-10 have a strange behavior when we use it with PoE : the power LED keeps blinking red & white really fast & the camera's LED is blinking green really fast.
We don't have a Power Supply to make more tests but is this might be an hardware issue ?
Solved! Go to Solution.
11-29-2017 10:36 AM
Quentin,
From the SX10 installation guide, "If there is a problem with the start up, the LED turns red. Please contact support for
assistance." I would first verify that your Ethernet cabling is good and actually passes the correct PoE current/voltage and that the switch and specific port are providing PoE as expected. If there are no issues with those things, then I would contact Cisco TAC for troubleshooting and possible RMA.
11-29-2017 10:36 AM
Quentin,
