SX10 and support with Touch 8/10
With the new SX10, the user interface seems to be the remote control and probably the web interface.
Can we pair the SX10 to a Touch 8 or Touch 10 unit?
If not now, is it planned?
2 Accepted Solutions
amehla
Hi Richard,
As of now SX10 only supports TRC 6 remote control with it.
it can support touch panel in future, however there is no confirmation on it.
Patrick Sparkman
Touch 10 is now supported with the SX10 starting with TC7.2.0.
Discussion and link to release notes can be found here: TC7.2.0 now released
8 Replies 8
amehla
Hi Richard,
Thanks for the information.
That was what I was afraid of.  If you have any links back into the BU, strongly suggest the touch 10 and possibly the 8 be options sooner than later.
They are a much better user interface and experience than the remote.
Hi Richard,
Did I read something about "Proximity" with regard to the SX10? Does this have anything to do with an app running on a tablet device (or some such) that when it is in close proximity to the SX10, you will be able to use it as a touch interface?
Cheers,
Chris
Mark Turpin
Level 5
Level 5
While we wait for the Touch option, is there any documentation regarding SX10 compatibility with a Crestron or AMX controller?
-Mark Turpin
Mark -
According to the data sheet and an image I've seen of SX10 is that there is no serial RS232 port.  So any way to use Crestron or AMX would have to be done via TCP communication.
Patrick Sparkman
Besides purchasing the Touch 10 touch panel. What additional product do we need on our end to complete this task? We currently have 9 SX10's
When you purchase a Touch 10 (part number CTS-CTRL-DV10), it will come with two flat grey Ethernet cables and a PoE injector, everything you need to connect it to the SX10.
