sx20 touch panel
itay00002
When turning off the unit completely(sx20) the touch screen panel stay on.is that how it supposed to be? (do I need to turn it off by unpluging the power cord?)
As the Touch8 is powered completely seperately from the SX20, it does not power down when the SX20 is powered off.  If you really must turn it off, you will need to do so via the power cord/outlet that the Touch8's power comes from.
Wayne
Please remember to rate responses and to mark your question as answered if approprate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Anas Abueideh
Level 9
Level 9
I didn't find a settings for that in the user guide
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/codec-c-series/tc6/user_guide/profile-series-codec-c-series-qs-c20-sx20-qs-mx-series-touch-user-guide-tc63.pdf
what is the firmware version ? try to upgrade it.
Anas
don't forget to rate the helpful posts
Wayne
Wayne
itay00002
Dear Wayne/everybody
just to be sure:
please see the picture attached.
is this what i am suppose to see on the touch panel when i shut down the VC unit?
if i will get the 10" touch panel whould it be any different?
can i shut it down without unplug the power cord?
thanks
The message you are seeing is expected, since the touch panel remains on while the codec is turned off, as it still tries to contact the codec.  Touch 8 and 10 are no different, as they both use an external power supply to power the touch panel.  There is no way that I know to power off the Touch 8 without unplugging it from the power.
