TCP/UDP port usage for the EX90
rfrome
Does anyone have a list of port usage for the EX90s they can share?
t.svatek
Level 3
Level 3
there is no Port reference for any Endpoint like EX90, EX60 and C-Codecs. The Port References for TMS, MCU and VCS are also very different.
You can advise the needed ports by looking into this doc:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X4_to_X7.pdf
I wish for christmas a complete port reference for all boxes.
There were these documents H323 and SIP but these are now outdated I believe as you can set the range of media ports use in the codecs by the commands ...
xConfiguration RTP Ports Range Start: 2326
xConfiguration RTP Ports Range Stop: 2486
in the later releases of TC software (TC4/5), so now for the media you can define the port range used.  SIP and H323 signalling will still use the ports mentioned in the documentation.
