TCS Recording Aliases Configuration
Hi everybody,
I'm trying to configure a Recording alias that leaves in some of the description de H323id or the E164 of the calling party.
Is it posible to and variables in the description so this to be taken into consideration?
Federico
For now that is not an out of the box solution. I am not aware that there are any
variables on the TCS which could be used to archive that.
As the TCS supports an API it could be possible to generate some kind of policy service
for the VCS which creates and places the call to the TCS and adds the caller id as some kind
of infomation to the recording. (a bit like a conductor for recording; maybe that could be a feature
request for the conductor)
5 Replies 5
Saurabh Gupta
Level 3
Level 3
Hi ,
I would recommend to use a generic recording alias like abc@xyz.com or something like 12345@xyz.com to be used as a recording alias.
And also use similar alias for playback .
Saurabh
Hi Saurabh,
Thanks for your reply.
I'm using a general allias for all endopoints but what I want to record Is the calling party who called this general alliases and made the recording.
Federico
Nothing you can do as far as recording alias is concerned, unless you allocate a speficic recording alias to a specific end-point, but that'll soon get out of hand if you have a lot of end-points.
You could find the details in the call log in TMS though, but that's about it.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Hi Jens,
That's what we are dooing me cuestion was regarding if there was a way for in the default description set a variable that allows to know that without having to trace TMS call log
