10-15-2013 04:48 AM - edited 03-18-2019 01:58 AM
Dear all
I have a new TCS6.0 on UCS Server which is running very well.
problem is as soon are open the Live unicast stream via WMP direct link
rtsp://192.168.1.1/testlive
sometime the stream are stopped and see the message "Network busy..." sometimes after a while the stream are synchronised and works well.
showing the stream via WebBrowser via Silverlight, I don`t have any Problems.
I have got this issue also on the older TCS5.3 plattform
Any Idea why I have the Problem with direct WMP?
Is it possible to open a direct Windows with Silverlight with the same publishing point?
Any input appreciated
Georg
10-15-2013 06:47 AM
Since you are seeing the WMP error/issue regardless of TCS platform, and the viewing in the web browser via SIlverlight seems to be fine, it could possibly be a client issue. Here is a post from a Microsoft support forum with some steps that can be done on the client that might help:
03-25-2014 09:01 AM
dear all
I got more or less the same problem as georg. the wmp stops after a while.
In the wmp statistics (local player on tcs) i see the selcted bit rate drop, as well as the bandwidth in use.
checking the performance monitor of the windows media services on the tcs i see al lot of late reads and late sends. even with no client connected i get a lot of late reads. also the current file read rate every now and then drops to zero. is that normal behaviour of the tcs encoder?
any ideas?
best regards
igor
