Hi Forman,
In case you are trying to deploy multiple C codecs I suggest to use the Cisco VCS or Expressway solution
The Cisco VCS/Expressway is most suitable for large-scale deployments. It allows you to connect across organizations without requiring any exceptions or extra ports to be opened on the firewall. In this solution, both organizations need to have a Cisco VCS and you need to configure a connection between the two Cisco VCSs.
In case you have only few endpoints that you are taking into consideration , the C series support H323 NAT Mode / H.323 NAT address and also Cisco TelePresence Expressway technology H.460.18, H.460.19 Firewall Traversal.
For more details kindly asked to cunslut the admin guide available at :
http://www.cisco.com/en/US/docs/telepresence/endpoint/codec-c-series/tc4/administration_guide/profile_c60-c40_and_codec_c60-c40_administrator_guide_tc42.pdf
