Bookmark
Subscribe
4573
TelePresence Testing Sites
Hello!
May you give me the addresses of systems that I can use to test my cisco/tandberg systems over the internet.
Thank you!
5 Replies 5
Jens Didriksen
Level 9
Level 9
H.323 and SIP:
loopback@cisco.com
loopback@rtp.ciscotac.net
Also see
http://vtctest.pointsofdata.com/
(H.323 only)
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Thanks Jens!
I have got a standalone C20 system that is not registered to any telepresence infrastructure.
Given what I have, which protocol do I use for the test?
H.323? SIP?
HI Kelvin.
With no configuration you would have to use SIP.
//Marius
It requires SIP registrar for SIP URI dialling to work...which he hasn't got...so H.323 it is.
/jens
If it has TC4.2 or later, then you can use H.323 URI dialling in addition to "normal" IP adddress dialling, so all of those sites will work with your C20 - unless you have some firewall issues.
/jens
