Hi -
I have installed a Tandberg Profile 52' and all is working well. However, I am using the Touch Panel which is operating fine for making and answering calls however, the mute button and the volume bar on the side are not working. They do not respond to anything. When the panel booted for the first time they did light up.
Is there a setting on the Codec which has the volume bar turned off? Or is there a defect in the code/unit?
