09-23-2014 03:22 AM - edited 03-18-2019 03:26 AM
I’m happy to announce that Cisco TMS 14.5 is available.
Please read the external release notes for more details.
TMS 14.5
/Magnus
09-23-2014 06:08 AM
Mangus -
Any idea why the published 14.5 admin and install docs have a DRAFT watermark? Not sure what others have it, those are the only two I've opened so far.
09-23-2014 06:44 AM
Hi Patrick
There has been a glitch here. I have notified the doc team and they are going to update the document asap. It should still be the final version (just that the watermark is still there). Thanks for letting me know.
/Magnus
09-23-2014 06:51 AM
Release notes also mention TMSPE 1.3 -- any idea when this will be released. Would like to get our lab upgraded. Thanks.
09-23-2014 08:40 AM
Ditto; TMSPE 1.3 is listed as a prereq. One would think this would mean TMSPE 1.3 should have been released first, or at the very least that the release is imminent.
09-23-2014 10:48 AM
TMS 14.5 is compatible with TMSPE 1.3 but its not a pre-req. If they where then they would have been released together. However TMSPE 1.3 is not far away, I don´t have the exact date but I would say it´s only days away.
/Magnus
10-02-2014 04:39 PM
Upgraded to 14.5 and 1.3 this morning - and now have lost all phone books from scheduling interface - see https://supportforums.cisco.com/discussion/12316351/phonebooks-disappeared-scheduling-interface-after-upgrading-tms-145
/jens
09-30-2014 07:59 AM
We completed our internal process to publish the software and it should be posted shortly.
10-01-2014 01:57 AM
TMSPE 1.3 has now been published on cisco.com.
Kjetil
09-23-2014 03:16 PM
Expect TMSPE 1.3 any day. Last minute process issue we need to sort out.
Andrew
TMS PM
09-23-2014 03:17 PM
Cisco TelePresence Management Suite Provisioning Extension (TMSPE) v1.3 will be released imminently. Engineering is completing some last remaining regulatory and internal documentation processes before releasing.
Rest assured though, TMSPE 1.2 has been smoke-tested with TMS v14.5 before release and works together.
09-24-2014 06:08 AM
Then TMSPE 1.2 should also be listed on the compatibility table along with 1.3. Otherwise the implication is that only the things on the table are compatible and all others are not.
09-23-2014 05:08 PM
Having read about the unmanaged bridges feature prior to the release of this, I was quite excited as it would allow external parties to schedule multiple endpoints to dial our TP servers and visa versa, but then I read this in the release notes:
"A Network Integration license key must be purchased for each unmanaged bridge"
Looking at the pricing, it is literally cheaper to buy a licensed TP server 7010 than one of these license keys, so I don't see this feature getting alot of use unfortunately.
09-23-2014 05:56 PM
Why does this feature require an option key to enable, it's just providing TMS managed endpoints to dial into conference bridges that essentially you're creating, what kind of integration does it give you?
09-23-2014 09:24 PM
I'd hope that you'd only need to buy one Network Integration Licence per TMS Server, and not one for each unmanaged bridge. At ~$50k US list price for the TMS Network Integration License - I'm hoping that's been documented wrong in the release notes!
I can understand that an unmanaged bridge may use a "System License" for each one (~$5400 US list for 25 licenses), and there may be a requirement to have a single L-TMS-NETINT present on the TMS server for it to work... but one for each just sounds completely wrong (unless there's new licencing coming out that's not yet mentioned anywhere).
Hopefully Magnus or Michael can confirm.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
