TMS enabled Webex with CMS?
Georg Kehrer
Level 4
Level 4
Dear all
Is it possible to have TMS Enabled Webex with CMS as in the past with TP Server ?
Cisco Collaboration Meeting Rooms (CMR) Hybrid Configuration Guide (TMS 15.0 - WebEx Meeting Center WBS30)
https://www.cisco.com/c/en/us/td/docs/telepresence/infrastructure/tms/config_guide/cmr_hybrid_15_0/cmrh_b_cmr-hybrid-configuration-guide.html
But I would like to have this with Cisco Meeting Server, is that possible ?
Thanks for any input ?
Best Regards
Georg
PJMack
Level 7
Level 7
Short answer, no. Webex CMR Hybrid only works with the legacy Cisco Telepresence Server and MCU product lines, not CMS. This is not likely to change as Webex has evolved and the hybrid media node will be the solution here going forward.
Okay, what I was thinking.
Video Mesh Node or CMS on premise, if CMS add Personal Meeting Room manually.
Thanks.
Best Regards
Georg
