TMS , MCU
Yazen Alaa
Kindly i have confused between TMS , MCU , my concerns are the following below :
what is the main different between TMS , MCU ?
when can i use TMS , MCU in network , in the words when i shall i need TMS and when  shall i need MCU ?
shall i need to integrate MCU with TMS , both with VCS controll ? and how it will be
i am waiting your feedback ASAP
thanks
Jens Didriksen
Level 9
Level 9
MCU: http://www.cisco.com/c/en/us/products/conferencing/telepresence-mcu-5300-series/index.html - Multisite Control Unit - allows you to connect multiple participants in the one conference. Can be either hardware- or software-based.
TMS = Telepresence Management Suite - see  http://www.cisco.com/c/en/us/products/conferencing/telepresence-management-suite-tms/index.html - is a management application which allows for complete management of end-points, MCUs, VCS etc, provisioning of JabberVideo clients, and call scheduling.
So, TMS is for management, MCU is for calls involving multiple participants.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
thanks for fast reply
thanks..
You can register both the MCU and the VCS to TMS for management and as far as MCU and endpoints are concerned; scheduling purposes. TMS is a management application, you don't "integrate" it as such with anything.
I suggest you take a look at the admin guide: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/admin_guide/Cisco_TMS_Admin_Guide_14-1.pdf
And, of course, the MCU is registered with the VCS for call admission and control purposes, just like you would register end-points to the VCS.
If you want to use features like "Multway", then take a look at the Telepresence Multiway Deployment Guide relevant to the software version of your VCS: http://www.cisco.com/c/en/us/support/unified-communications/telepresence-video-communication-server-vcs/products-installation-and-configuration-guides-list.html
/jens
Please rate replies and mark question(s) as "answered" if applicable,
