05-26-2013 08:50 PM - edited 03-18-2019 01:11 AM
Can I create a scheduled Muli-party conference in TMS - Booking the MCU resources (But No EndPoints) So as to be able to have dial in users only. (with Pin) .
The MCU being set for say maximum partisipants (EG: 4 Video in Template) . Users could be 4 Jabber Clients Registered to CCUM over sip Trunk.
OR perhaps 3 + 1 VCS registered. ?
An Externsion to the question is have Outlook Via TMSXE book the conference (also via template I assume).
Thanks (all latest Version TMS/VCS/8.6 CCUM and 5320 MCU)
Solved! Go to Solution.
05-28-2013 11:23 PM
Depends on the scheduler you use.
If you use the normal TMS scheduler, you could add 4 video dial in participants to the meeting.
With the smart scheduler you can book real systems and add some dial-in participants.
With TMSXE you can also book only rooms.
I'm using a workaround for TMSXE with some customers:
You can add two dummy room systems, which have a URI like -do-not-route-room-1- and also sync them via TMSXE to a Exchange calendar. If someone books both this systems, a conference will be automatically added on the MCU, because TMS can't control this dummy rooms.
I would like to see a feature in TMS, where you can configure special mailboxes with TMSXE to add dial in participants, i.e. a room mailbox for 2 participants and one for 5.
05-28-2013 11:23 PM
05-29-2013 04:28 AM
Hi Paul,
With regards to TMSXE and your comments, I would suggest you deploy the Cisco form in the user environment. When you create a conference from Outlook, you can then add enough dial-in participants from the Cisco form. Then you would receive a confirmation email including the dial-in method for third party to dial-in.
rgds,
Dale
05-29-2013 04:36 AM
Hi Dale,
in most cases we can't deploy the form for Outlook, either because the customer does not allow it or we even have different systems using the outlook calenders, like Outlook Web Access, Linux or OS X client.
TMSXE 3.1 does not also use exchange mailboxes not as a room, but for special purposes like scheduling WebEx Meeting. It would be a really good feature to add dial-in ports to a conference via a mailbox.
05-29-2013 04:58 AM
That's can be done using the latest and greatest Productivity Tool, i.e. ties Telepresence and Webex together now
And here's a youtube that somewhat discusses that 'tie up'...albeit SS is being discussed:
https://www.youtube.com/watch?feature=player_detailpage&v=sKs49ZVNuVM#t=383
05-29-2013 07:06 AM
not all customers are WebEx customers and as far as I know, the european WebEx cloud is not yet Telepresence enabled :-(
05-30-2013 05:07 AM
+1 for such a mailbox feature.
btw: it´s available on CTS-Manager: There you can define an VC endpoint, map it to a mailbox and if you add it to your booking, you´ll get the interop dial in info within the confirmation email.
05-30-2013 05:09 AM
Open an enhancement/feature request guys...if you haven't already done so
/dale
05-30-2013 01:57 PM
I haven't opened a feature request yet, but told Andrew Bell as TME for TMS at a partner event.
05-31-2013 12:28 AM
Thanks Paul. I've also had a chat with Michael McGary about this as well and we agree its a good idea but obviously needs some further thought. Therefore, and since this enhancement related, I'll let the Product Managers discuss further and then present the case to engineering
cheers,
Dale
05-31-2013 04:13 AM
Thanks Dale!
05-29-2013 05:48 PM
Thnaks Paul and Dale. ..I agree with comment on TMS re rooms with partisipants limits (for Dial in) . The MCU supports Max Video and max Voice per conference. Would be nice to have similar setting (TMS )when adding dial in users to a conference. (or and yes it is TMSXE for scheduling as you guessed)
Also Have WEBEX Inhouse server in agenda - But its can't be intergrated either.
