TMS upgrade failed: Unable to communicate with system
Arbenjamin
Dear all,
The endpoint are failed to upgrade from the TMS.
Based on the System Upgrade Activity Status, it reports as follows,
Event Postponed to 2014-xx-xx.
The event repeats for 48 times, and upgrade event is deleted finally.
Based on TMS page, the connectivity of the endpoint is Reachable on LAN.
The setting can be modified and the configuration templates can be updated by the TMS.
TMS configuration: Secure-Only Device Communication : OFF(Sorry, i have missed the information)
Endpoint configuration:
Provisioning
Address: <TMS IP>
ExternalManager protocol: HTTP
Best Regards,
Benjamin
7 Replies 7
Martin Koch
Interesting that the external manager protocol is http and your tms config is secure only.
Could you tell us a bit more about your deployment.
Which TMS version do you run, which endpoints do you try to upgrade, which are the software versions you are trying to upgrade from and to?
Any more info in the logs of the TMS or the endpoints?
Sounds very much like bug: CSCug21218
<B>Symptom:</B>
Unable to upgrade systems from TMS
<B>Conditions:</B>
HTTP is disabled on the TMS server
Optional: Secure device communication only
Optional: HTTPS only is enabled on the endpoint.
<B>Workaround:</B>
Enable HTTP on the TMS server
I don´t know about the TMS version you are on but this was an issue before as I remember because I created this bug on TMS 14.1.1. TMS 14.3 should resolve the issue, but you can utilize the workaround.
/Magnus
Dear Magnus,
Thanks for your sharing.
The TMS version is 13.2
Best Regards,
Benjamin
Hi Magnus,
I am having the same issue, running TMS 13.2.2.  I did a quick packet capture from TMS and I see that all traffic is effectively all in tlsv2 (https) when I try the software upgrade for an Ex60 running tc7.1.  How do you "Enable HTTP on the TMS server" exactly?  Secure device communication setting is also OFF.
Cheers,
Andre
Andre - I have the same issue running TMS 13.2.2.  I have Secure Device Communication setting OFF.
Did you find out how to enable HTTP on the TMS server exactly?
thanks!
Dear Martin,
I am sorry that some information is missed.
TMS version is 13.2.
Target endpoint EX90: 5.1.7 ->5.1.11
Best Regards,
Benjamin
Kjetil Ree
Hi Benjamin,
With TMS 13.x and TC 5.x, the upgrade mechanism consists of TMS trying to do a HTTP POST to the endpoint with the entire software image. Endpoint software images are large, typically ~200 MB, could it be that a firewall or something in the network is killing the connection before the upload completes?
I recommend getting a Wireshark trace of a failed upgrade to troubleshoot your problem futher.
Kjetil
