unable to configure VCS-e
Jayant Kohli
Hi Team,
I am unable to configure VCS-E 7.1 deployed on a VM usning the following doc:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Cisco_VCS_Control_with_Cisco_VCS_Expressway_Deployment_Guide_X7-1.pdf
In step 8, where it talks about traversal zone, while configuring Cisco VCS-E, it mentione "select Traversal Server" and i dont see any option in the drop down menu.
the screenshot is attached. The licenses on VCS is uploaded with LIC-VCSE-100 option key.
Please advise how to proceed further.
Rgds.
J
5 Replies 5
Mike Assel
Level 4
Level 4
Out of curiosity, does it say "Cisco TelePresence Video Communications Server Expressway" at the top of the GUI?
Nope, it says VCS-Control so does it mean its missing a key.Is it R-VMVCS-EXPWY-K9?
Jens Didriksen
Level 9
Level 9
Look under Status/Overview and check if "Expressway" option key is installed.
Should look something like this:
Options
0 Non Traversal Calls, 40 Traversal Calls, 2500 Registrations, 70 TURN Relays, Expressway, Encryption, Interworking.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
It doesnt show even after uploading LIC-VCSE-100 key. Looks like i need another key R-VMVCS-EXPWY-K9.Is it?
LIC-VCSE-100 is the key for 100 traversal calls, the first part of the option key will end Y100. For this to be a VCS Expressway you need the key that the first part ends T00.
VCS Control and VCS Expressway can both make traversal calls - take the media, for a number of different reasons. But Traversal Server (and TURN) functionality is only available on VCS Expressway, not VCS Control.
