Unable to SSH into VCS
Here is my situation. I am trying to SSH from a 3560 switch into my VCS but I get the follwing error:
" Switch#ssh 172.16.200.19 [Connection to 172.16.200.19 aborted: error status 0]"
debug ip ssh output:
Jun 18 2013 14:47:01.127 UTC: SSH CLIENT0: protocol version id is - SSH-2.0-OpenSSH_5.9
Jun 18 2013 14:47:01.127 UTC: SSH CLIENT0: sent protocol version id SSH-2.0-Cisco-1.25
Jun 18 2013 14:47:01.127 UTC: SSH2 CLIENT 0: send: len 280 (includes padlen 4)
Jun 18 2013 14:47:01.127 UTC: SSH2 CLIENT 0: SSH2_MSG_KEXINIT sent
Jun 18 2013 14:47:01.135 UTC: SSH2 CLIENT 0: ssh_receive: 536 bytes received
Jun 18 2013 14:47:01.135 UTC: SSH2 CLIENT 0: input: packet len 968
Switch#ENT 0: partial packet 8, need 960, maclen 0
Jun 18 2013 14:47:01.135 UTC: SSH2 CLIENT 0: ssh_receive: 432 bytes received
Jun 18 2013 14:47:01.135 UTC: SSH2 CLIENT 0: partial packet 8, need 960, maclen 0
Jun 18 2013 14:47:01.135 UTC: SSH2 CLIENT 0: input: padlen 11
Jun 18 2013 14:47:01.135 UTC: SSH2 CLIENT 0: received packet type 20
Jun 18 2013 14:47:01.135 UTC: SSH2 CLIENT 0: SSH2_MSG_KEXINIT received
Jun 18 2013 14:47:01.135 UTC: SSH2: kex: server->client aes128-cbc hmac-sha1 none
Jun 18 2013 14:47
Switch#:01.135 UTC: SSH2: kex: client->server aes128-cbc hmac-sha1 none
Jun 18 2013 14:47:01.135 UTC: SSH2 CLIENT 0: hostkey algo not supported: client ssh-rsa, server ssh-dss
Jun 18 2013 14:47:01.135 UTC: SSH CLIENT0: Session disconnected - error 0x00
I'm not very familiar with SSH but could it be that the switch is running RSA keys and from the debug output, it looks like the VCS uses DSS.
The switch is running SSHv2. VCS SSH is enabled.
10 Replies 10
mahkrish
Level 3
Level 3
Hi, Can you let us know the exact requirement to perform ssh from switch to VCS ? are you able to ssh from your desktop/laptop using ssh clients ?
BR, Mahesh Adithiyha
The current setup doesn't allow us to ssh from a laptop or desktop. I have remote access to a switch, which has a router, MCU, and VCS connected to. From there, I would like to ssh to the VCS. SSH is working in the switch because I can ssh into the router from it.
ahmashar
Level 4
Level 4
This looks like you hit this bug CSCtc58970
Ahmad
Ahmad,
The link is not coming up.
sorry about that.
what version of IOS are you running?
The switch is running c3560-ipservicesk9-mz.122-55.SE1. The VCS is version 7.2, I think (don't have access to the equipment at the moment). Router is 15.1.4M6.
I am not 100% sure if its a bug or a feature. If the switch simply does not support dss and the vcs not ssh you cant do much besides hoping hat the cisco switch will support it in future versions.
Think of using a vpn / firewall opening / portforward to use it or think of using the dual interface option
or some out of band management (serial port / vmware / ...)
it means there is a mismatch in key negotiation algorithms so it couldn't handshake the connection.
so the workaround would be SSH from a Linux/Unix/Windows client to either box and it will work as this is a key negotiation issue between switch and VCS.
Thank you for your input.
shkn
Hi ,
Try the Putty software for ssh into the device
Shyam
