upgrade onprem codec plus ce9.13 to RoomOS 11.5
jaheshkhan
Level 4
Level 4
we would like to upgrade on prem cisco webex codec plus from ce 9.13 (ce 9.13.0 990355df13a 2020-06-12) to stable version RoomOS 11.5.2
but i cannot see what upgrade path has to follow for this upgrade?
Can Any one help in this regard?
I would like to upgrade it from codec GUI and not from CUCM .
5 Replies 5
b.winter
Everything you probably need to know is stated in the release notes of the target version:
https://roomos.cisco.com/print/WhatsNew/ReleaseNotesRoomOS_11#upgrading-software-on-a-cisco-room-device
And the release notes for RoomOS 10 states the following:
https://roomos.cisco.com/print/WhatsNew/ReleaseNotesRoomOS_10
my question is that what is the path in this case.
do i need to upgrade as below:
ce 9.13 > 9.15.6 > 10.19 > 11.5.2
or can I go
ce 9.13 >  11.5.2
or
ce 9.13 > 9.15.6 >  11.5.2
Have you read what I posted? Doesn't seem so...
From CE 9 --> RoomOS 10 --> RoomOS 11
From memory, you need to go to 11.1.xx first before 11.5.2.4.  But the rest should be okay.
To obtain comprehensive information about the upgrading process and pathway, please refer to the release notes for the target version (RoomOS 11.5.2.). All necessary details, as highlighted by @b.winter, can be found there.
