Upgrade VCS via TMS to X7.1
martin1.plank
Level 4
Level 4
Hi outhere,
With "Software manager" in TMS 13.2 there seem to be a problem. Uploading s42700x7_1_0.tar.gz doesn't work.
Is there a known issue?
How can I upgrade VCS without TMS?
Hope anyone can help
Martin
2 Accepted Solutions
Anthony Thomson
Level 3
Level 3
You can upgrade the VCS directly by logging in to the VCS web page, and going to Maintenance --> Upgrade and uploading the new file there.
Tomonori Taniguchi
Adding to software upgrade from web GUI (from maintenance > upgrade), Cisco recommends taking system backup before software upgrade.
The system backup file can be create and download from web GUI as well (maintenance > backup and restore).
Anthony Thomson
Level 3
Level 3
'cause using TMS all the time I totally forgot this methode!
Greetings from Austria!
Martin
Tomonori Taniguchi
Thanks Tomonori!
Martin
