URI Pattern and REGEX
wilfred malana
I am trying to reverse the effect of this following following regex;
.office@{User.emailAddress['^.+?@'='']}
This particular regex is from the Jabber provisioning doc. What I am trying to accomplish is to strip out the domain from the email address or leave all characters before the @ sign.
Thanks.
Tomonori Taniguchi
The Regex document available at https://supportforums.cisco.com/docs/DOC-25084 might be handy for you.
BTW, please note if you are using provisioning, please be careful for remove domain for all search rule as provisioning/presence etc. use full URL format for signal handling.
Tomonori Taniguchi
Simple way to remove domain part from URI but leave “@” using Regex is…,
  • Pattern string: (.+)@.+
  • Pattern behavior: Replace
  • Repalce string: \1\@
wilfred malana
Thanks. I actually want the @ part removed as well.
Tomonori Taniguchi
Simple way to remove domain part from URI including “@” using Regex is…,
or if you want to apply this only for SIP domain configured on VCS then…,
  • Pattern string: (.+)@%localdomains%
Of course you can strip specific domain name from call string including "@".
Assume you want to remove domain name, domain.com, then...,
  • Pattern string: (.+)@domain.com
Tomonori Taniguchi
