VCS-C endpoints unable to call each other
J_Vansen_S
Level 3
Level 3
VCS-Control
Software version              X7.0.1
Software                            build266732
Software name                 s42700
Hardware Serial Number 52A22835
Problem statement: SIP endpoints unable to call each other
  • Sip domain: vcs.xxx.local
  • 2 endpoints: EX60 and EX90 both registered successfully to VCS as 2002@vcs.xxx.local and 2003@vcs.xxx.local
  • Search rule: Source any; Mode Any Alias, Target LocalZone.
  • Default Subzone has 2 number of registration
Call History:
  • Status 404 / Not found
Incoming call setup paramaters
Bandwidth node: Default Subzone
Source alias 1sip:2002@vcs.xxx.local (Url)
Target alias 1sip:2003@vcs.xxx.local (Url)
ProtocolSIP
Address10.10.13.157:5060
TransportTCP
ReasonNot found
Cause404
Please advise on what we had configured wrong or is missing
9 Replies 9
Michael Boscia
Level 4
Level 4
Can you tell us how unit A calls unit B?
What search rules do you have?
Do you have any transforms?
Can you provide more of you relevant configuration?
Hi there,
Unit A calls unit B by dialing 2002 or 2003 vice versa.
I have only 1 search rule and no transforms.
First thing to try is to change "On successful match" from "stop" to "continue".
Also, Maintenance--->Tools--->Locate is a very handy tool which will show you, in most cases, where/why the search fails.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
The search history page will also be useful for troubleshooting these types of issues.
Can you verify that when you go to Status > Registrations > By alias, that the 'Alias' column shows these two registrations as exactly '2002@vcs.xxx.local' and '2003@vcs.xxx.local' (Or the actual domain you are using, rather), and that the search history shows that the LocalZone is being searched with the same destination alias?
- Andreas
Hi there,
thanks for your info.
  • Yes that the Registration alias shows exactly 2002@vcs.xxx.local and 2003@vcs.xxx.local
  • Search history shows that Status "Not found"
Is there something missing? Or some licenses or option key that i have missed out?
Can you paste the entire search history for this search, and not just the top part?
Hi Andreas, Thanks for your assistance. Apparently i have the exact setup and config on the VCS-Express starter pack with FINDme option that works fine. Not too sure what defers from the VCS-C without fineme.
  • Search (2)
    • State: Completed
    • Found: False
    • Reason: Not Found
    • Type: SIP (INVITE)
    • CallSerial Number: a349cd80-a636-11e1-b517-0010f321e11e
    • Tag: a349ce66-a636-11e1-832b-0010f321e11e
    • StartTime: 2012-05-25 14:55:39
    • Duration: 0.01
    • Source (1)
      • Authenticated: True
      • Aliases (1)
        • Alias (1)
          • Type: Url
          • Origin: Unknown
          • Value: 2003@vcs.esuria.local
      • Zone (1)
        • Name: LocalZone
        • Type: Local
      • Path (1)
        • Hop (1)
          • Address: 10.10.13.159:5061
    • Destination (1)
      • Alias (1)
        • Type: Url
        • Origin: Unknown
        • Value: sip:2002@vcs.esuria.local
    • SubSearch (1)
      • Type: Transforms
      • Action: Not Transformed
      • ResultAlias (1)
        • Type: Url
        • Origin: Unknown
        • Value: 2002@vcs.esuria.local
      • SubSearch (1)
        • Type: Admin Policy
        • Action: Proxy
        • ResultAlias (1)
          • Type: Url
          • Origin: Unknown
        • SubSearch (1)
          • Type: FindMe
          • Action: Proxy
          • ResultAlias (1)
            • Type: Url
            • Origin: Unknown
          • SubSearch (1)
            • Type: Search Rules
            • SearchRule (1)
              • Name: LocalZoneMatch
              • Zone (1)
                • Name: LocalZone
                • Type: Local
                • Protocol: SIP
                • Found: False
                • Reason: Service Unavailable
                • Gatekeeper (1)
                  • Address: 10.10.13.10:0
                  • Alias (1)
                    • Type: Url
                    • Origin: Unknown
              • Zone (2)
                • Name: LocalZone
                • Type: Local
                • Protocol: H323
                • Found: False
                • Reason: Not Found
                • Gatekeeper (1)
                  • Alias (1)
                    • Type: Url
                    • Origin: Unknown
This part is interesting:
    • Zone (1)
      • Name: LocalZone
      • Type: Local
      • Protocol: SIP
      • Found: False
      • Gatekeeper (1)
        • Alias (1)
          • Type: Url
          • Origin: Unknown
"Service unavailable" does not look quite right. Is 10.10.13.10 the IP address of the 2002@vcs.esuria.local endpoint? What type of endpoint is this, EX60 or EX90? And what software version is it running?
- Andreas
Aldo Insfran
Hi J,
Did you solve this?
I have exactly the same issue except that "Reason=Timeout"
