Bookmark
Subscribe
4906
VCS Dialing features
sidris-sid
Hi expert,
I have concerns regarding VCS starter pack, I need to clarify if the following point can be support by VCS or not:
1-          VCS integration with CUCM :
Currently the integration is working fine but I need VC unit register to VCS to dial first (*) or (#) then CUCM extension, currently from CUCM its working fine, if it should work can someone provide me search rule which will allow call by * and #, I tried but it’s never working with me.
2-          Dial to VC over Internet:
I think to achieve this task I need only Public IP address for VCS then the VC unit will used the VCS as Gateway for outside calls…right? If my unit will use SIP while outside VC is H323 (Public unit not register to VCS) does still my VC will go through, you should consider that I have VCS starter pack and interworking between SIP – H323 is for register only?
3-          Allow internal Video conference calls:
I think to allow Video conference calls from internet to internal VC units just external caller need to call via VCS is there any specific ports I need to enable it on firewall in order to allow external call to reach via SIP (internal unit could be EX90 and Movi)
Thanks in advance.
Saeed
2 Accepted Solutions
Hi Saeed!
Did you try the call with Movi/JabberVideo? At least there I saw this behavior as well.
Some background:
http://en.wikipedia.org/wiki/Percent-encoding
http://www.ietf.org/mail-archive/web/sip/current/msg16522.html
http://www.ietf.org/rfc/rfc3986.txt
So if these old postings are still valid, movi is doing it correct, but the VCS does not seem to unescape
the escaped # in the URI.
Anyhow, as a workaround,  why don't you just add an additional regex search rule for (if I wollow your example)
%23(2\d+)@ in addition to (#)(2\d+)@
A replacement could be #\1@cucm or whatever you need to have.
Btw is there a reason why you put the # in ()? each () will generate to a numbered variable for the replacement.
\1 = #
\2 = the number dialed starting with 2
Use the "check pattern" tool in the maintenance/tool section to check if your regex is giving you the right results.
I just tried such kind of %23 to # search rule and it worked fine for me.
Saeed: Please rate the answer using the stars below!
Tomonori Taniguchi
> 1- I have configured (\*) and its working as its explained above.
Good!!
> 2- I have configured the following search rule: (#)(2\d+)@  but still not working when I checked VCS logs
> I have noticed that when I dialed VC device sip:#29009@ its convert to sip:%2329009@
> so when # is modified to %23 , also I checked VCS transformation page and its fine.
I assume you have configure search rule as below.
Pattern Type: Regex
Pattern string: (#)(2\d+)@customer.com.*
Pattern behavior: Replace
Replace string: \2@customer.com
What SIP UA are you using for initiate the call (#29009@)?
I managed to reproduce what you are seeing by using C-series Endpoint which Endpoint converts # to %23 before sending out URL to VCS.
|INVITE sip:%2329009@customer.com SIP/2.0
Via: SIP/2.0/TCP 172.16.1.115:5060;branch=z9hG4bK67e8b870f634cbdfbdd307fd915e8898.1;received=172.16.1.115;rport=33924
Call-ID: 7d8ce4e425a57161@172.16.1.115
CSeq: 100 INVITE
Contact: <>705555@customer.com;gr=urn:uuid:91b67478-121e-56d7-811c-459f8a3b06aa>
From: "C40" <>705555@customer.com>;tag=a0b99b94a3b48f17
To: <>%2329009@customer.com>
This is relate to ASCII-URL Encoding converting..
Unfortunately pattern check feature on VCS won't give correct response when you test with # (or even %23) as receive SIP to address is not starting with "#" this case.
9 Replies 9
Alok Jaiswal
Hi Saeed,
going by one by one to your question.
Que 1.
you can have a search rule created in a fashion which will be a "REGEX" in form for e.g. (#)(\d+)@ then set the search rule to replace and use the one given here \2@ and target would be CUCM zone.
this will send the call to CUCM.
Que 2.
yes, thats right. You need a public ip on the VCS starter pack. Please note that in case if you are using a 1:1 NAT option then you need a dual nic option key to specify NAT on the VCS.
Que3.
You are right on 3rd point as well. to allow calls please check the below deployment guide for the firewall port usage.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X4_to_X7.pdf
Alok
Tomonori Taniguchi
Adding comment what Alok reply on question 1.
The call string starting with # follow by one or more numeric number with sip domain works fine with (#)(\d+)@ as search rule with regex format.
However * is representing “0 or more repetitions of previous character or expression” for regex format, therefore need a bit careful how to write search rule with regex format.
To use * as call string, then need to add “\” front of * in regex string to identify “*” as actual character in call string.
Best fit search rule by using regex for matching both “#” and “*” follow by numeric number with sip domain is
[\*|#](\d+)@cisco.com.*
   ->  [a|b] : this regex mean a or b
   ->  \*     : this regex mean * (* as actual calling string charactor)
This single regex will handle call search for call string staring “* and “#” follow by one or more numeric number and sip domain.
Thanks Alok & Tomonori for the valid posts I have tested the above recommendations and here is my feedback:
2-          I have configured the following search rule: (#)(2\d+)@  but still not working when I checked VCS logs I have noticed that when I dialed VC device sip:#29009@ its convert to sip:%2329009@ so when # is modified to %23 , also I checked VCS transformation page and its fine.
Any idea what is the reason behind such issue.
Saeed IDris
Hi Saeed!
Some background:
\1 = #
Tomonori Taniguchi
Good!!
Pattern Type: Regex
CSeq: 100 INVITE
Tomonori Taniguchi
This is what Endpoint actually sending to VCS (# has already convert to %23)
Session Initiation Protocol
   Request-Line: INVITE sip:%2329009@customer.com SIP/2.0
       Method: INVITE
       Request-URI: sip:%2329009@customer.com
           Request-URI User Part: %2329009
           Request-URI Host Part: customer.com
       [Resent Packet: False]
   Message Header
       Via: SIP/2.0/TCP 172.16.1.115:5060;branch=z9hG4bK4993826f41e4e7bcef732befd40693df.1;rport
           Transport: TCP
           Sent-by Address: 172.16.1.115
           Sent-by port: 5060
           Branch: z9hG4bK4993826f41e4e7bcef732befd40693df.1
           RPort: rport
       Call-ID: 28a2171f67e374cd@172.16.1.115
        CSeq: 100 INVITE
           Sequence Number: 100
           Method: INVITE
           Contact-URI: sip:705555@customer.com;gr=urn:uuid:91b67478-121e-56d7-811c-459f8a3b06aa
               Contactt-URI User Part: 705555
               Contact-URI Host Part: customer.com
           Contact parameter: gr=urn:uuid:91b67478-121e-56d7-811c-459f8a3b06aa>
       From: "CIBU.Tokyo.C40" <>705555@customer.com>;tag=e98a9d9fa4f3bf8f
           SIP Display info: "CIBU.Tokyo.C40"
           SIP from address: sip:705555@customer.com
               SIP from address User Part: 705555
               SIP from address Host Part: customer.com
           SIP tag: e98a9d9fa4f3bf8f
           SIP to address: sip:%2329009@customer.com
               SIP to address User Part: %2329009
               SIP to address Host Part: customer.com
       Max-Forwards: 70
       Route: <172.16.1.30>
       Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,REFER,NOTIFY
       User-Agent: TANDBERG/516 (TC5.0.0.273156)
       Supported: replaces,100rel,timer,gruu,path,outbound
      Session-Expires: 1800
       Content-Type: application/sdp
       Content-Length: 2361
   Message Body
       Session Description Protocol
           Session Description Protocol Version (v): 0
           Owner/Creator, Session Id (o): tandberg 46 3 IN IP4 172.16.1.115
OK, Good news its working Thanks to you all and special Thanks to Martin & Tomonori I have tested and its working as expected.
One thing more I have some concerns and I hope if someone can assist me on those points:
1- Does VCS Starter pack version 7.0.1 integrate with Microsoft AD (if yes, for all TP video unit or just Movi)
2- Does VCS support to register MOVI from VPN?
3- Is there any documents which can help on deploy VCS Dial plan.” expression rules”
Look forward to hear from you very soon.
Saeed
Hi Saeed,
thank you for voting and the feedback.
Regards your questions:
1) could you define a bit more how you interpret "integrate with MS AD"?
* automatic import of users: no, you would need TMS and a standard vcs and its probisioning for that
* manual vcs user account creation and match password towards AD: Maybe, at least it also has
the ad service under vcs configuration, authentication, devices ( https:///ntlm )
But in general I would recommend a non starter pack TMS&VCS setup.
2) In general yes. The VCS itself does not care where the packets come from, its just ip.
In some scenarios you will end up that media is beeing send directly to the ip of the vpn endpoint.
This might bring in some complications as well. Also depending on the deployment the dual
interface option might be needed.
Also the CPU load on the movi computer with the vpn software might be higher as its now double
encrypted.
Points 1/2 would be perfect to discuss with your Cisco TelePresence partner.
3)  The Cisco documentaiton is quite good. Just look at:
http://www.cisco.com/en/US/products/ps11337/tsd_products_support_series_home.html
Especially the VCS Admin guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/admin_guide/Cisco_VCS_Administrator_Guide_X7-1.pdf
X7.1 release, VCS-E Starter Pack support AD integration both account authentication (user authentication) and device authentication (NTLM authentication for Movi/Jabber Video authentication).
Yes, it support in general as long as VCS reachable back to VPN client IP address range.
Please note, usually VPN client have separate MTU size specified by VPN router.
Please make sure you have reasonable MTU size.
VCS Administrator Guide contain RegEx dial plan example.
I just upload document of simple regular expression explanation to https://supportforums.cisco.com/docs/DOC-25084 as well for your reference.
