09-07-2012
09:07 AM
- last edited on
03-25-2019
09:05 PM
by
ciscomoderator
This is my first post here and I would like to know your thoughts about the problem below:
Scenario: VCS running 7.1 with B2BUA and a SIP connection using TLS. Microsoft Lync 2010 (one FEP), no FindMe users, just static route.
TLS SIP connection is active on both sides. Manage to call from endpoints to Lync clients, unfortunally from Lync clients to endpoints I'm getting a response "400 Unable to decode SDP". The static route is set to send calls to port 5061 on VCS.
Any ideas?
Thanks.
Regards.
Solved! Go to Solution.
09-07-2012 09:47 AM
Didler,
the static route from Lync towards VCS should not point to port 5061 when using B2BUA, but rather the B2BUA listening port for incoming OCS/Lync connections, which defaults to 65072.
This is described in more detail on pages 67 and 68 of the OCS/Lync deployment guide for X7.1.
Hope this helps,
Andreas
09-07-2012 05:17 PM
Hi Didler,
its mentioned uner the VCS- Lync integration guide as well. Page ref # 56
Video endpoint reports that it does not support the Lync client SDP
If a video endpoint reports that it does not support the Lync client SDP, for example by responding “400 Unable to decode SDP” to a SIP INVITE message containing the Lync multi-part mime SDP sent to it:
Check whether the Lync server is sending calls to the VCS incoming IP port, rather than the B2BUA IP port that should be receiving the incoming SIP messages.
Reconfigure Lync server to send calls to the B2BUA IP port.
you can clear the routes using below commands. for e.g. if the video domain is "abc.com"
Get-CsStaticRoutingConfiguration -identity global | Select{$_.matchUri -eq "abc.com"}-ExpandProperty Route
$delroute=Get-CsStaticRoutingConfiguration -identity global | Select{$_.matchUri -eq "abc.com"}-ExpandProperty Route
Set-CsStaticRoutingConfiguration -identity global -Route @{Remove=$delroute}
and then add a new static route pointing to B2BUA port 65072
$route = New-CsStaticRoute -TLSRoute -destination "vcs.abc.com" -port 65072 -matchuri "abc.com" -usedefaultcertificate $true
Set-CsStaticRoutingConfiguration -identity global -route @{Add=$route}
cheers
Alok
09-07-2012 09:47 AM
Didler,
Hope this helps,
Andreas
09-07-2012 02:28 PM
Thanks for your reply Andreas.
Let me try this and I will get back to you soon.
09-07-2012 05:17 PM
Hi Didler,
cheers
Alok
09-10-2012 01:31 PM
Thanks Guys,
Calls to and from MS Lync are working now.
Didier
