10-13-2006 09:37 AM - edited 03-17-2019 08:49 PM
We currently use the 7912 series IP phones and are looking for a way to mount them vertically. We have purchased a locking wall mount (http://www.cisco.com/en/US/products/hw/phones/ps379/prod_installation_guide09186a00800a8689.html) that is supposed to work with all 7900 series phones. However, it using mounting pin holes to mount to a phone and these pins holes do not exist on the 7912 model phone. Please explain how this mount is supposed to be installed to the 7912 phone.
Solved! Go to Solution.
10-13-2006 10:47 AM
Chad:
Here's the universal wall mount kit install guide.
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_installation_guide09186a00801d0356.html
It has the 7902, 7905, 7912 models shown.
Tom
10-13-2006 10:47 AM
Chad:
Tom
10-14-2006 08:37 AM
Hi Chad,
Just to add a note to Tom's good post, I am pretty sure that the 7912 uses a different Wall mount kit. Have a look at the different part numbers;
7905,7912
CP-LCKNGWALLMNT2=
7940,7960
CP-LCKNGWALLMOUNT=
You probably ended up with the Wall Mount Kit shown in the attached doc;
Hope this helps!
Rob
Please remember to rate helpful posts.....
