11-11-2015 02:01 PM - edited 03-18-2019 05:12 AM
I used TMS to perform a backup on our infrastructure devices (VCS-C and E cluster) which are devices added in TMS..
TMS said the back up was completed, but where did it put the back up files? I was assuming I could run a back up each week/each time I make a change and then store those files perhaps on a file share somewhere in case I ever needed to do a restore...
Thanks for the assistance!
Solved! Go to Solution.
11-11-2015 02:58 PM
This has been asked before :) - see https://supportforums.cisco.com/discussion/11510741/tms-backup-question
For my VCS clusters I much prefer to create system backups on the individual VCS itself instead of TMS prior to doing any upgrades, changes etc.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
11-12-2015 07:45 AM
As Jens mentions, if you perform a backup of the TMS managed systems it backup that data to the TMS database (tmsng). There is no option to store this backup data outside of the database, if you wish to do this, you'll be required to perform the backups of these systems yourself manually.
This is exactly the same scenario as your other question posted here: backing-tms. Which by the way, hasn't been marked as being answered even though it has been, if you would, please do so.
11-11-2015 02:58 PM
/jens
11-12-2015 07:45 AM
