C40 not booting
davidoates
Having problems with our TelePresence Intergrator C40. I wasn't present for the change, but another tech changed the IP, GW, etc and rebooted through the web interface. Once it rebooted it never came back up. Connecting to the codec serial port I get the following message:
Couldn't connect to TANDBERG software.
I've attached the full boot sequence. Any ideas of how I can get an OS uploaded or to fix this?
My hands are tied, not getting a response from the vendor, I took over this system which was put in place 3 months ago and I'm unable to get ahold of the people that coordinated the install. The S/N is registered to another support contract not covered under any of my contracts associated with my profile when trying to open a TAC and I'm getting alot of heat to get this thing fixed ASAP.
Thanks for any help!
-Dave
59 Replies 59
Hello Vivek,
Yes I tryed but the problem remains.
Paulo Ferreira
Hi Paulo,
I sent one message to you with one suggestion.
Vivek
Hi Paulo,
I just noticed in one of your messages above you mentioned that you ran the following command :
AMERICA> setenv americapkg s52000tc5_1_0.pkg
I believe the command you need to run is :
Setenv saturnpkg
In this case it should be :
AMERICA> Setenv saturnpkg s52000tc5_1_0.pkg
Can you please try the process again with this command and update?
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Hi Mubashshir,
Yes, I also notice that previously and I correct that. The final result was the same.
Paulo Ferreira
Hi Paulo,
At this time we have exhausted all the troubleshooting. I would recommend you to open a TAC case with us for this issue and we can maybe take a webex session and perform the whole operation ourselves to make sure its working fine. We will make sure that this issue is taken care of in a timely manner.
Mubashshir Akhtar
Hi Paulo,
Before we go ahead with the TAC case, can you please  try to perform one more step. I was researching on the issue and I think  I have found out the problem.
Can you please download  the package file for TC4.2.2 and then try to perform the operation  again?
Here's the link of the download :
ftp://ftp.tandberg.com/pub/software/endpoints/tc/tc4/s52000tc4_2_2.pkg
Please  try the steps again only the difference is to replace your current  package file with this one. Also since the package file is changing, the  commands in the SATURN prompt would also change to the new filename.
Please try these steps and update with the results.
Mubashshir  Akhtar
Hello, can somebody help for me. I try upload new software for my Tandberg c20, and happen sonthing wrong - cant no upgrade no downgrade,  so with this directions try fix https://supportforums.cisco.com/docs/DOC-23161, but not luck.
I think maybe    pkgextract.elf   and u-boot not suitable for C20?
Because C20 name is ORION
I made log when try upload software, maybe make some problem?
How I can Fix this, because now tandberg dont start
Log:
Press 'b' to enter u-boot prompt
Press 'c' to stop autoboot:  4
ORION> setenv serverip xxx.xxx.134.206
ORION> setenv tftp_path pkgfiles
ORION> setenv orionpkg s52000tc2_0_1.pkg
ORION> run pkgex
BOOTP broadcast 1
DHCP client bound to address xxx.xxx.134.209
NAND erase: device 0 whole chip
Skipping bad block at  0x09b40000
Skipping bad block at  0x0ea40000
Skipping bad block at  0x27640000
Skipping bad block at  0x48700000
Skipping bad block at  0x4d980000
Skipping bad block at  0x582c0000
Skipping bad block at  0x7cb40000
Erasing at 0x7ffc0000 -- 100% complete.
OK
yaffs: Mounting /flash
Using TSEC0 device
TFTP from server xxx.xxx.134.206; our IP address is xxx.xx.134.209
Filename 'pkgfiles/saturn.pkg'.
Load address: 0x2000000
Loading: *
TFTP error: 'File not found??f•wabcdefghi??×ö' (1)
Not retrying...
Copy pkgextract.elf from NOR flash to 0x1000000
## Starting application at 0x00042e78 ...
Buildtime: Jan  4 2012 11:31:59
Not a PKG file (170173190)
Failed to read PKG header
## Application terminated, rc = 0x1
image1 is not a directory
Reprogram NOR from /flash/image1
Un-Protected 1 sectors
. done
Erased 1 sectors
Copy /flash/image1/bootsw to 0x01000000... File not found
Write /flash/image1/bootsw (4294967295) to NOR flash
NOR allready contains correct data
Copy /flash/image1/pkgextract.elf to 0x01000000... File not found
Write /flash/image1/pkgextract.elf (4294967295) to NOR flash
File /flash/image1/S01710.bin.wrapper not found
ORION> Orion
Unknown command 'Orion' - try 'help'
ORION>        SN: F1AN2
Unknown command 'SN:' - try 'help'
ORION>        SN: PB039 TSEC1
ORION> Hwmon: 43
Unknown command 'Hwmon:' - try 'help'
ORION> Press erverip 210tc2_0_1.pkg
Unknown command 'Press' - try 'help'
ORION> ORION> run pkgexe: device 0 whole chip
Unknown command 'ORION>' - try 'help'
ORION> Skipping bad blox27640000
Unknown command 'Skipping' - try 'help'
ORION> Skipping bad blo582c0000
ORION> Skipping bad blo/flash
ORION> Using TSE0 device 'pkgfiles/saturn.pkg'.
Unknown command 'Using' - try 'help'
ORION> Load address: 0xretrying...
Unknown command 'Load' - try 'help'
ORION> Copy pkgextract.Buildtime: Jan  4 2012 11:31:59
Unknown command 'Copy' - try 'help'
ORION> Not a PKG file (image1 is not a directory
Unknown command 'Not' - try 'help'
ORION> Reprogram NOR frlash/image1/bootw to 0x01000000... File not found
Unknown command 'Reprogram' - try 'help'
ORION> Write /flash/imaflash/image1/pkgextract.elf to 0x01000000... File not fou
nd
Unknown command 'Write' - try 'help'
ORION> Write /flash/imadata
ORION> File /flash/imag
Teck Chye Tang
Do not change the name to Orion, leave it as Saturn
But now then try reply I get this...
LOG:
setenv serverip 213.226.134.206
ORION> setenv saturnpkg s52000tc2_0_1.pkg
ORION> run pkgex
BOOTP broadcast 1
Erasing at 0x0 --   0% complete.Erasing at 0x1440000 --   1% complete.Erasing at 0x28c0000 --   2% complete.Erasing at 0x3d40000 --   3% complete.Erasing at 0x51c0000 --   4% complete.Erasing at 0x6640000 --   5% complete.Erasing at 0x7ac0000 --   6% complete.Erasing at 0x8f40000 --   7% complete.Skipping bad block at  0x09b40000
Erasing at 0xa3c0000 --   8% complete.Erasing at 0xb840000 --   9% complete.Erasing at 0xccc0000 --  10% complete.Erasing at 0xe140000 --  11% complete.Skipping bad block at  0x0ea40000
Erasing at 0xf5c0000 --  12% complete.Erasing at 0x10a00000 --  13% complete.Erasing at 0x11e80000 --  14% complete.Erasing at 0x13300000 --  15% complete.Erasing at 0x14780000 --  16% complete.Erasing at 0x15c00000 --  17% complete.Erasing at 0x17080000 --  18% complete.Erasing at 0x18500000 --  19% complete.Erasing at 0x19980000 --  20% complete.Erasing at 0x1ae00000 --  21% complete.Erasing at 0x1c280000 --  22% complete.Erasing at 0x1d700000 --  23% complete.Erasing at 0x1eb80000 --  24% complete.Erasing at 0x1ffc0000 --  25% complete.Erasing at 0x21440000 --  26% complete.Erasing at 0x228c0000 --  27% complete.Erasing at 0x23d40000 --  28% complete.Erasing at 0x251c0000 --  29% complete.Erasing at 0x26640000 --  30% complete.Skipping bad block at  0x27640000
Erasing at 0x27ac0000 --  31% complete.Erasing at 0x28f40000 --  32% complete.Erasing at 0x2a3c0000 --  33% complete.Erasing at 0x2b840000 --  34% complete.Erasing at 0x2ccc0000 --  35% complete.Erasing at 0x2e140000 --  36% complete.Erasing at 0x2f5c0000 --  37% complete.Erasing at 0x30a00000 --  38% complete.Erasing at 0x31e80000 --  39% complete.Erasing at 0x33300000 --  40% complete.Erasing at 0x34780000 --  41% complete.Erasing at 0x35c00000 --  42% complete.Erasing at 0x37080000 --  43% complete.Erasing at 0x38500000 --  44% complete.Erasing at 0x39980000 --  45% complete.Erasing at 0x3ae00000 --  46% complete.Erasing at 0x3c280000 --  47% complete.Erasing at 0x3d700000 --  48% complete.Erasing at 0x3eb80000 --  49% complete.Erasing at 0x3ffc0000 --  50% complete.Erasing at 0x41440000 --  51% complete.Erasing at 0x428c0000 --  52% complete.Erasing at 0x43d40000 --  53% complete.Erasing at 0x451c0000 --  54% complete.Erasing at 0x46640000 --  55% complete.Erasing at 0x47ac0000 --  56% complete.Skipping bad block at  0x48700000
Erasing at 0x48f40000 --  57% complete.Erasing at 0x4a3c0000 --  58% complete.Erasing at 0x4b840000 --  59% complete.Erasing at 0x4ccc0000 --  60% complete.Skipping bad block at  0x4d980000
Erasing at 0x4e140000 --  61% complete.Erasing at 0x4f5c0000 --  62% complete.Erasing at 0x50a00000 --  63% complete.Erasing at 0x51e80000 --  64% complete.Erasing at 0x53300000 --  65% complete.Erasing at 0x54780000 --  66% complete.Erasing at 0x55c00000 --  67% complete.Erasing at 0x57080000 --  68% complete.Skipping bad block at  0x582c0000
Erasing at 0x58500000 --  69% complete.Erasing at 0x59980000 --  70% complete.Erasing at 0x5ae00000 --  71% complete.Erasing at 0x5c280000 --  72% complete.Erasing at 0x5d700000 --  73% complete.Erasing at 0x5eb80000 --  74% complete.Erasing at 0x5ffc0000 --  75% complete.Erasing at 0x61440000 --  76% complete.Erasing at 0x628c0000 --  77% complete.Erasing at 0x63d40000 --  78% complete.Erasing at 0x651c0000 --  79% complete.Erasing at 0x66640000 --  80% complete.Erasing at 0x67ac0000 --  81% complete.Erasing at 0x68f40000 --  82% complete.Erasing at 0x6a3c0000 --  83% complete.Erasing at 0x6b840000 --  84% complete.Erasing at 0x6ccc0000 --  85% complete.Erasing at 0x6e140000 --  86% complete.Erasing at 0x6f5c0000 --  87% complete.Erasing at 0x70a00000 --  88% complete.Erasing at 0x71e80000 --  89% complete.Erasing at 0x73300000 --  90% complete.Erasing at 0x74780000 --  91% complete.Erasing at 0x75c00000 --  92% complete.Erasing at 0x77080000 --  93% complete.Erasing at 0x78500000 --  94% complete.Erasing at 0x79980000 --  95% complete.Erasing at 0x7ae00000 --  96% complete.Erasing at 0x7c280000 --  97% complete.Skipping bad block at  0x7cb40000
Erasing at 0x7d700000 --  98% complete.Erasing at 0x7eb80000 --  99% complete.Erasing at 0x7ffc0000 -- 100% complete.
OK
Using TSEC0 device
TFTP from server xxx.xxx.134.206; our IP address is xxx.xxx.134.209
Filename 'pkgfile/s52000tc2_0_1.pkg'.
Loading: *
TFTP error: 'File not foundö6¾' (1)
Not retrying...
. done
Erased 1 sectors
ORION>
Where I do mistake? what now I must corectly to do
Is your folder where you save all your files pkgfiles or pkgfile ?
Folder name pkgfiles  (C:\Program Files\Cisco Systems\Cisco TFTP Server\pkgfiles)
Teck Chye Tang
In your last error, you're pointing to pkgfile. Check your command and you can see .
Still same error. There is Log:
ORION> setenv serverip xxx.xxx.134.247
ORION> run pkgex
BOOTP broadcast 1
DHCP client bound to address xxx.xxx.134.214
save exit: isCheckpointed 1
OK
Using TSEC0 device
TFTP from server xxx.xxx.134.247; our IP address is xxx.xxx.134.214
Loading: *
TFTP error: 'File not foundô"…2' (1)
Not retrying...
. done
Erased 1 sectors
I  think the reason of this error can be - not correctly working Cisco  TFTP server, because it dont show any Logs, any activity then try upload  software.
Maybe I do something wrong.
I set for Cisco TFTP  server root address (C:\Program Files\Cisco Systems\Cisco TFTP  Server\pkgfile). Maybe need make some more in this?
I don't quite understand.  Or if I have understand you wrongly.   In your previous comment, you wrote :
"Folder name pkgfiles  (C:\Program Files\Cisco Systems\Cisco TFTP Server\pkgfiles)"
In your command, I still see this, the tftp_path is still pkgfile and not pkgfiles.
