Can I use remote control of SX20 with Codec C20.
s.sitthichai
Remote control of C20 is loss. Can I use remote control of SX20 with Codec C20 ?
I cannot try do it myself. Thanks.
Jens Didriksen
Level 9
Level 9
Yes, they both use TRC5 for the TC software versions, the new CE8 software for SX series use TRC6.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
OK, Thank you.
From your meaning, incase TRC6 it cannot use remote control together right ?
Yes, TRC6 only works with SX10 (all software releases) and SX20 running CE8.x software.
TRC5 works with all C-series systems and SX20 when it uses TC software.
/jens
And, technically, the TRC5 remote does work on the CE8.x software, just that it puts up a big message on the screen saying you're using an unsupported remote if you press one of the buttons that isn't present on the TRC6 remote (which, when comparing the two is quite a few buttons that no longer work).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate,
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
