sip spam call attack and MCU and vcs-e
baselzind
Level 6
Level 6
as far as i know sip call spam attacks is done against video conference units connected with a public ip address , i have disabled sip but im not sure if my mcu and vcs-e with public address are vulnerable to them? do they pose any security threats to them? and if so , how? and what can be done about it?
2 Accepted Solutions
Jens Didriksen
Level 9
Level 9
This is a well known issue, and it affects H.323 as well as SIP, take a look at the below threads:
https://supportforums.cisco.com/discussion/12340591/nuisance-h323-calls-sx20
https://supportforums.cisco.com/discussion/12336591/sourceh323idcisco-incomingcalls
https://supportforums.cisco.com/discussion/12508641/cisco-source-spam-calls-stepped-complexity
https://supportforums.cisco.com/discussion/12613681/attack-vcse
There are a lot more threads dealing with this issue, the above is just a small selection. :)
You don't need to disable SIP on the VCS-E, all you need to do is turn of SIP UDP unless you require it for voice services.
You can protect yourself by using a CPL on the VCS-E which will prevent the calls from going through to your MCU, or anything else you have sitting behind the VCS-E. This is assuming you are using a VCS-C/VCS-E combo, with the VCS-C behind a firewall and the VCS-E outside the firewall, e.g. in DMZ.
Having endpoints and/or MCU sitting in the wild with public IP addresses are just asking for trouble.
These scans, by the way, are mainly looking for systems which will allow them to make free international phone calls.
/jens
Please rate replies and makr question(s) as "answered" if applicable,
Please rate replies and mark question(s) as "answered" if applicable.
saif musa
Level 4
Level 4
hi,
chick below link, it may helps..
https://supportforums.cisco.com/discussion/11760521/handling-unwanted-sip-call-attempts-vcs-es
6 Replies 6
Jens Didriksen
Level 9
Level 9
/jens
what sort of services are used by Port 5060 UDP ? will it affect CISCO jabber?
Non-encrypted call signalling, SIP UDP is now turned off by default in the VCS-E and Cisco recommends it stay that way unless you have voice services running on it, as call signalling on 5060 also uses TCP.
It will not affect neither Jabber (requires CUCM) nor JabberVideo, which requires VCS (not CUCM).
/jens
is the sip call spamming restricted to only port udp 5060? why is that?
UDP 5060 is a port used by SIP devices to register to a VCS for example. The scanner looks for this open port and if it finds one, it knows there may be a chance of reaching a device on/or through that IP to make calls, ie: toll fraud.
saif musa
Level 4
Level 4
hi,
