08-16-2020 11:47 PM
What is difference between:
Cts-sx20n-12x-k9 and
Cts-sx20n-c-12x-k9
(-c- in part number) ?
Is it different in HW or SW ? Or?
08-17-2020 04:45 AM
08-23-2020 08:36 PM
I believe the only real difference was the software version that was pre-installed on the device:
Cts-sx20n-12x-k9 = SX20 came with CE8 installed
Cts-sx20n-c-12x-k9 = SX20 came with CE9 installed
Otherwise, they are identical, and can all be updated to the current software version.
Please remember to mark helpful responses and to set your question as answered if appropriate.
03-02-2022 12:26 AM
Hi all,
Above table shows that Part Number that hasn't -C- has newer version CE9.
In other hand I think software version that can change easily can't change Part number.
Is there any other differences between them?
Thanks in advance,
Taheri
03-03-2022 08:01 PM
Other than the software version that they were shipped with, no, there were no other differences.
Note that these older SX20 systems are now end of sale (since 29 October 2019), and the CE8 software is even older and end of support as of 31 May 2021, so it's highly recommended that you run at least CE9.15+ on them all anyway.
