Add pauses to dial strings
kevin.sullivan
We are running CUCM 7.1
we are using an external conference bridge and would like to be able to route a call and out pluse the conf code.
Example: route call to +7770000020,,,294xxxx# to enter the conf
Is this possibe?
Chris Deren
It is a new feature of CUCM 9.0, so you would need to upgrade to the latest version to take advantage of it.
Chris
paolo bevilacqua
You can use my script "speed-dial with pauses" that works with any version of CM and CME.
It can be acquired on the website mentioned in my profile.
