AIM-CUE keep rebooting issue
cooltreedan
Hi everyone,
Please help my AIM-CUE module, it keep rebooting again and again, that happens when I found it not booting correct, and tried to install from boot helper mode, the boot helper installation didn’t successful, because it’s just rebooted, not like normally boot helper installation.
First, when I from the router, I reset the module, IF I DIDN’T DO ANYTHING, the CUE module it’s just keep rebooting again and again, here’s the output:
Router#service-module service-Engine 0/1 reset
Use reset only to recover from shutdown or failed state
Warning: May lose data on the the NVRAM, nonvolatile file system or unsaved configuration!
Do you want to reset?[confirm]
Trying to reload Service Module Service-Engine0/1.
From the CUE, I got:
Initializing memory.  Please wait. ...
*Jul 13 22:53:11.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down 256 MB SDRAM detected
BIOS Version: Cisco SE-AIM 01.02
BIOS Build date: 08/14/03
System Now Booting ...[BOOT-ASM]
Please enter '***' to change boot configuration:
*Jul 13 22:53:31.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
root cmd : root (hd0,0)
Filesystem type is reiserfs, partition type 0x83
kf: a1 : /bzImage root=/dev/hda1 ro plat=aim
kf: a2 : /bzImage root=/dev/hda1 ro plat=aim
in grub_open: /bzImage root=/dev/hda1 ro plat=aim
in grub_open1: /bzImage root=/dev/hda1 ro plat=aim
in grub_open2: /bzImage root=/dev/hda1 ro plat=aim
in grub_open3: /bzImage root=/dev/hda1 ro plat=aim 1
in grub_open4: /bzImage root=/dev/hda1 ro plat=aim
kernel_func: kt: 0
Unable to load image
in boot func: kt: 0
Unable to boot image
Initializing memory.  Please wait. ... 256 MB SDRAM detected
BIOS
*Jul 13 22:53:51.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down Version: Cisco SE-AIM 01.02
*Jul 13 22:54:11.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
kernel_func: kt: 0
in boot func: kt: 0
*Jul 13 22:54:21.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down... 256 MB SDRAM detected
*Jul 13 22:54:41.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
kernel_func: kt: 0
in boot func: kt: 0
*Jul 13 22:55:01.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down 256 MB SDRAM detected
*Jul 13 22:55:21.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
kernel_func: kt: 0
in boot func: kt: 0
*Jul 13 22:55:41.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down[BOOT-ASM]
And it just keep rebooting forever, and you can see the Interface Service-Engine0/1 keep flapping, up and down, up and down.
Second, same from the router, I reset the module, IF I HIT “***” TO GET IN THE BOOT-LOADER MODE, AND I WANT TO RE-INSTALL THE IMAGE, I got the following output:
*Jul 13 23:01:41.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down... 256 MB SDRAM detected
Please enter '***' to change boot configuration: ***
ServicesEngine Bootloader Version : 2.1.14
ServicesEngine boot-loader>
*Jul 13 23:02:01.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to up
ServicesEngine boot-loader> config
IP Address [192.168.1.6] >
Subnet mask [255.255.255.0] >
TFTP server [192.168.1.2] >
Gateway [192.168.1.5] >
Default Helper-file [cue-installer.nm-aim.3.2.5] >cue-installer.nm-aim.3.2.5
Default Boot [none|disk] [disk] >
Default BIOS [primary|secondary] [primary] >
Default bootloader [primary|secondary] [primary] >
Updating flash with bootloader configuration
1.2.3.4.5.6.7.8.9.10.11.12.done.
ServicesEngine boot-loader> boot helper
nw_boot: 0 cue-installer.nm-aim.3.2.5
Me: 192.168.1.6, Server: 192.168.1.2, Gateway: 192.168.1.5
Loading cue-installer.nm-aim.3.2.5
Dbg: Final image size: 11466076
Debug: bl_sz: 95040
Debug: cisco_bl_sz: 59694
0x0000007f 0x00000045 0x0000004c 0x00000046 0x00000001 0x00000001 0x00000001 0x
00000000 0x00000000 0x00000000
cisco_cl_addr: 0x1001930
Debug: bl_sz: 95040
loader_addr: 0x1200000
Cisco BootLoader start
verify_netboot_img
found signature
Found bootable
img_start: b sig_len: 172 sig_start: 5
bl_sz: 95040
Cisco_bl_sz: 59694
after buf_len: 4256
after KEY_InitMem
reading key: 0
reading key: 1
reading key: 2
reading key: 3
reading key: 4
reading key: 5
after aesop_RSA_keyarray_read
in verifysignature_md5, MD5 hash generated now, str format:hexmd5:005e374ebde6699317c76f8a6b94a790
Verifying signature now...
calling RSA decrypt now
mem ptr: 0 704 832 968 1040 1172 1184 1196 1208 1220 1228 1244 1268 1284 1300 1316 1332 1344 1360 1384 1400 1664 1804 2080 2224 2364 2880 3396 3660 3924 4188 RSA decrypt returned:4294967295
verifysignature_md5, Orig MD5 hash generated during encryption:蘔躓#墼]?^7N芥i?莖妅敡?
mem ptr: 0 704 832 968 1040 1172 1184 1196 1208 1220 1228 1240 1260 1276 1288 1304 1320 1332 1348 1368 1380 1644 1784 2060 2204 2344 2860 3376 3640 3904 4168 RSA decrypt returned:33
verifysignature_md5, Orig MD5 hash generated during encryption:005e374ebde6699317c76f8a6b94a790
signatures match...
Image signature verified successfully
CISCO_BL: boot_image: 0x1200000
[LOADER]: image/plat/sz: 2/0/11466076
Aesop Helper: system image header: v=2, b=946332, i=10516786
Network boot: moving 3072 code bytes to 0x90000
Network boot: invoking kernel now
[BOOT-PHASE2]: booting kernel
Linux version 2.4.24 (bld_adm@bld-system) (gcc version 2.95.3 20010315 (release)) #1 Fri Mar 30 08:37:07 PST 2007
Platform: aim
setup.c: handling kernel log buf at [126.5MB]
setup.c: handling trace buf at [127MB]
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000007e80000 (usable)
BIOS-e820: 0000000007e80000 - 0000000007f00000 (reserved)
BIOS-e820: 0000000007f00000 - 0000000008000000 (reserved)
BIOS-e820: 0000000008000000 - 0000000010000000 (usable)
BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
256MB LOWMEM available.
On node 0 totalpages: 65536
zone(0): 4096 pages.
zone(1): 61440 pages.
zone(2): 0 pages.
DMI not present.
Kernel command line: root=/dev/ram ramdisk_size=200000 ramdisk_start=0x6000000 console=ttyS0,9600n8 plat=aim
Initializing CPU#0
Detected 298.895 MHz processor.
Calibrating delay loop... 596.37 BogoMIPS
Memory: 244896k/262144k available (1211k kernel code, 15324k reserved, 693k data, 96k init, 0k highmem)
kdb version 4.3 by Keith Owens, Scott Lurndal. Copyright SGI, All Rights Reserved
in atrace_init
log_head: h: 2138328399, t: 317757402, l: -1738732095, w: -28157, s: 221072279
Initializing trace buffer
log_head: h: 0, t: 0, l: 0, w: 0, s: 1047488
Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
Inode cache hash table entries: 16384 (order: 5, 131072 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 16384 (order: 4, 65536 bytes)
Page-cache hash table entries: 65536 (order: 6, 262144 bytes)
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 128K
CPU: Intel Celeron (Coppermine) stepping 0a
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
PCI: PCI BIOS revision 2.10 entry at 0xe5f7d, last bus=0
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
kinoded started
VFS: Disk quotas vdquot_6.5.1
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: devfs_debug: 0x0
devfs: boot_options: 0x1
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
Cisco ContentEngine Flash Driver Version 0.02
RAMDISK driver initialized: 16 RAM disks of 200000K size 1024 blocksize
eepro100.c:v1.09j-t 9/29/99 Donald Becker http://www.scyld.com/network/eepro100.html
eepro100.c: $Revision: 1.36 $ 2000/11/17 Modified by Andrey V. Savochkin <saw@saw.sw.com.sg> and others
eth0: PCI device 8086:1209, 00:04:9A:49:3C:70, IRQ 10.
  Receiver lock-up bug exists -- enabling work-around.
  Board assembly 668081-002, Physical connectors present: RJ45
  Primary interface chip i82555 PHY #1.
  General self-test: passed.
  Serial sub-system self-test: passed.
  Internal registers self-test: passed.
  ROM checksum self-test: passed (0xdbd8681d).
  Receiver lock-up workaround activated.
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX4: IDE controller at PCI slot 00:07.1
PIIX4: chipset revision 0
PIIX4: not 100% native mode: will probe irqs later
    ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:pio, hdb:pio
    ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:pio, hdd:pio
hda: STI 2d408003171218, CFA DISK drive
blk: queue c03210c0, I/O limit 4095Mb (mask 0xffffffff)
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: attached ide-disk driver.
hda: task_no_data_intr: status=0x51 { DriveReady SeekComplete Error }
hda: task_no_data_intr: error=0x04 { DriveStatusError }
hda: 2001888 sectors (1025 MB), CHS=993/32/63, DMA
init unit number == 0
Partition check:
/dev/ide/host0/bus0/target0/lun0: p1 p2
Model == STI 2d408003171218
Flash capacity == 2001888
init unit number == 1
IEEE 802.2 LLC for Linux 2.1 (c) 1996 Tim Alpaerts
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 2048 buckets, 16Kbytes
TCP: Hash tables configured (established 16384 bind 16384)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: Compressed image found at block 100663296
Freeing initrd memory: 10270k freed
VFS: Mounted root (ext2 filesystem) readonly.
Mounted devfs on /dev
Init flash stats for STI 1GB wear_planes=16
Init flash stats
Freeing unused kernel memory: 96k freed
INIT: version 2.86 booting
Started device management daemon v1.3.25 for /dev
mount: mount point /dev/pts does not exist
mounting sys fs ...
mount: unknown filesystem type 'sysfs'
/dev/root has gone 38480 days without being checked, check forced.
1067 inodes used (17%)
12 non-contiguous inodes (1.1%)
# of inodes with ind/dind/tind blocks: 311/15/0
28839 blocks used (80%)
0 bad blocks
0 large files
838 regular files
60 directories
0 character device files
0 block device files
0 fifos
14 links
160 symbolic links (160 fast symbolic links)
0 sockets
1072 files
FILESYSTEM CLEAN
Remounting the root filesystem read-write...
kernel.sem = 1900 32000 32 128
vm.overcommit_memory = 1
                Welcome to Cisco Service Engine
Sun Jan  1 00:00:00 UTC 2006
********** rc.aesop ****************
rsrc_file:/etc/aim_rsrc_file
Populating resource values from /etc/aim_rsrc_file
rsrc_file:/etc/default_rsrc_file
Populating resource values from /etc/default_rsrc_file
==> Platform aim, management interface is eth0
IOS IP Address Registration complete.
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
192.168.1.0     *               255.255.255.0   U         0 0          0 eth0
default         192.168.1.5     0.0.0.0         UG        0 0          0 eth0
Size of buff is: 65536
65536 bytes written
Reading License... Parsing...
12 MAILBOX LICENSE
/tmp/license/voicemail_lic.sig
done
Reading Limits...
Processing: /lib/python2.3/startup/limits.xml
Processing: /bin/products/cue/limits.xml
done
INIT: Entering runlevel: 2
********** rc.post_install ****************
Changing owners and file permissions.
Change owners and permissions complete.
INIT: Switching to runlevel: 4
INIT: Sending processes the TERM signal
STARTED: dwnldr_startup.sh
        Welcome to Cisco Systems Service Engine Helper Software
Please select from the following
1       Install software
2       Reload module
3       Disk cleanup
(Type '?' at any time for help)
Choice: 1
Package name: cue-vm-k9.nm-aim.3.2.5.pkg
Server url: ftp://192.168.1.2/
Username: cisco
Password:
Downloading ftp cue-vm-k9.nm-aim.3.2.5.pkg
Bytes downloaded :  182040
Validating package signature ... done
- Parsing package manifest files... complete.
No installed manifests found.
- Checking Package dependencies... complete.
Downloading ftp cue-vm-langpack.nm-aim.3.2.5.pkg
Bytes downloaded :  1000665
Found Add-On Subsystem SID: e2e81cc6-39b5-47e1-9f83-b83c897fc50c Name: CUE Voicemail Language Support Version: 3.2.3.0
Found Add-On Subsystem SID: c28339fa-f7ae-4732-85ab-fa6c68b5de0c Name: CUE Voicemail Italian Version: 3.2.3.0
Found Add-On Subsystem SID: 49f09114-e0b0-4721-8b85-04be2064920c Name: CUE Voicemail European Spanish Version: 3.2.3.0
Found Add-On Subsystem SID: 27e5e2ab-1622-4c02-8a0a-cfad0d932148 Name: CUE Voicemail US English Version: 3.2.3.0
Found Add-On Subsystem SID: cf860289-67ac-4886-9295-a41e4c7a8487 Name: CUE Voicemail European French Version: 3.2.3.0
Found Add-On Subsystem SID: f0a41398-3917-4d49-b5ab-c2b39a80c121 Name: CUE Voicemail Latin American Spanish Version: 3.2.3.0
Found Add-On Subsystem SID: c4ca62e2-daff-40dc-b94e-bf20094bd700 Name: CUE Voicemail Mexican Spanish Version: 3.2.3.0
Found Add-On Subsystem SID: 88a84158-c090-4203-bde8-0d62eda200c7 Name: CUE Voicemail Arabic Version: 3.2.3.0
Found Add-On Subsystem SID: ab049397-cfad-4952-852a-8dfa69780cb8 Name: CUE Voicemail Dutch Version: 3.2.3.0
Found Add-On Subsystem SID: d60c3add-0c6b-4a99-8e5c-31019fe7939e Name: CUE Voicemail Swedish Version: 3.2.3.0
Found Add-On Subsystem SID: 683674a5-e6ef-4c97-8e05-efbba1e6fe47 Name: CUE Voicemail Canadian French Version: 3.2.3.0
Found Add-On Subsystem SID: b18bcd35-5a37-46af-b230-0d9c27713dec Name: CUE Voicemail Turkish Version: 3.2.3.0
Found Add-On Subsystem SID: fa803d25-9c89-4171-a14c-ec12d6ed6b8c Name: CUE Voicemail UK English Version: 3.2.3.0
Found Add-On Subsystem SID: 3f968fd0-6598-48e2-be1c-4af6c2e02e02 Name: CUE Voicemail German Version: 3.2.3.0
Found Add-On Subsystem SID: 88f73a6c-884d-4838-b162-1b544dd6583f Name: CUE Voicemail Danish Version: 3.2.3.0
Found Add-On Subsystem SID: a2ba4f96-3452-40c3-83ad-c442cb6bf42f Name: CUE Voicemail Brazilian Portuguese Version: 3.2.3.0
Found Add-On Subsystem SID: ea206a88-e44f-488b-a660-114a3b179065 Name: CUE Voicemail Korean Version: 3.2.3.0
Found Add-On Subsystem SID: 372fa3fd-1efb-4353-9005-45876646a351 Name: CUE Voicemail Mandarin Chinese Version: 3.2.3.0
Found Add-On Subsystem SID: 6cdfed34-6d45-48fd-afe0-717e589c9aa9 Name: CUE Voicemail Japanese Version: 3.2.3.0
Found Add-On Subsystem SID: 24cb0b00-ed1c-4463-bf6f-261b15dfb3e7 Name: CUE Voicemail Russian Version: 3.2.3.0
- Checking Manifest dependencies for subsystems in the install candidate list...
complete
WARNING:: Software installation will clear disk contents
Continue [n]? y
cleaning fs
prepfs.sh: aim reiser /mnt clean
hd_name: /dev/hda
hd_part: /dev/hda1
umount: /dev/hda1: not mounted
check_partition_count: 0
check_partition_flag: 1
Command (m for help): Partition number (1-4):
Command (m for help): Selected partition 1
Command (m for help): Command action
   e   extended
   p   primary partition (1-4)
Partition number (1-4): First cylinder (1-993, default 1): Using default value 1
Last cylinder or +size or +sizeM or +sizeK (1-993, default 993):
   e   extended
Partition number (1-4): First cylinder (6-993, default 6): Using default value 6
Last cylinder or +size or +sizeM or +sizeK (6-993, default 993): Using default value 993
Command (m for help): The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
mkreiserfs 3.6.19 (2003 www.namesys.com)
Starting payload download
File : cue-vm-full-k9.nm-aim.3.2.5.prt1 Bytes : 13448616kernel BUG at buffer.c:539!
invalid operand: 0000
cisco_rbcp
CPU:    0
EIP:    0010:[<c01311b5>]    Tainted: PF
EFLAGS: 00010282
EIP is at __insert_into_lru_list+0x1d/0x68 [kernel]
eax: 00000000   ebx: 00000002   ecx: c819c140   edx: c03047d4
esi: c819c140   edi: cc3ca980   ebp: cd523e38   esp: cd523e34
ds: 0018   es: 0018   ss: 0018
Process dwnldr (pid: 487, stackpage=cd523000)
Stack: 00000002 cd523e50 c0131ad0 c819c140 00000002 c819c140 00001000 cd523e5c
       c0131ae8 c819c140 cd523e68 c0133ed1 c819c140 cd523e8c c01835d6 cd523ed0
       cc3ca980 00001000 00000000 c819c140 00001000 00000000 cd523ef0 c01836ee
Call Trace:
[<c0131ad0>] __refile_buffer+0x54/0x60 [kernel]
[<c0131ae8>] refile_buffer+0xc/0x10 [kernel]
[<c0133ed1>] __mark_dirty+0x19/0x20 [kernel]
[<c01835d6>] __commit_write+0xea/0x154 [kernel]
[<c01836ee>] reiserfs_commit_write+0xae/0x1b0 [kernel]
[<c0183640>] reiserfs_commit_write+0x0/0x1b0 [kernel]
[<c0170018>] nfs_writepage_async+0x5c/0xdc [kernel]
[<c0125e79>] do_generic_file_write+0x279/0x39c [kernel]
[<c0126249>] generic_file_write+0xf1/0x10c [kernel]
[<c0184211>] reiserfs_file_write+0x21/0x60 [kernel]
[<c012ff68>] sys_write+0x94/0xf0 [kernel]
[<c0108b13>] system_call+0x33/0x40 [kernel]
Code: 0f 0b 1b 02 9f 69 23 c0 83 3a 00 75 05 89 0a 89 49 24 8b 02
<0>Rebooting in 2 seconds...
*Jul 13 23:07:41.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down 256 MB SDRAM detected
*Jul 13 23:08:01.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
kernel_func: kt: 0
in boot func: kt: 0
*Jul 13 23:08:21.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down[BOOT-ASM]
*Jul 13 23:08:31.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
kernel_func: kt: 0
in boot func: kt: 0
*Jul 13 23:08:51.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down 256 MB SDRAM detected
So you can see both TFTP and FTP works properly, normally after:
Continue [n]? y
Next step you should see the screen to choose the language, and continue.
But for mine, it didn’t shows me the choose language screen, however it went rebooting again, and then the rebooting just cycling as previous.
Anyone has encountered the same problem before? Or some experience guy can give me a help.
Thanks a lot.
Cooltree
5 Replies 5
cooltreedan
please everybody, thanks ahead!
paolo bevilacqua
You should use latest CUE software, not that old one.
Hi Paolo,
actaully I tried, but the same result, so that's why I choose the the old version to near the previouse version in the CUE, I believe is 2.x.x. Any other idea?
thanks,
Can be faulty hardware.
Don't know at this moment. I bought it on ebay, so before I ship it out, hope I can fix it.
thanks,
