03-24-2012 04:21 AM - edited 03-19-2019 04:39 AM
Guys I was just wondering if there is another platform that I could successfully install CUCM ( Home-Lab purpose) on other than VMware. I was looking for a permanently free / open-source solution.
Any suggestions guys?
Cheers
03-24-2012 04:50 AM
Why not VMware. There are free versions.
03-25-2012 02:07 AM
could you provide me a link to a free version please? my work station evaluation has come to an end and vmware now requires me to pay for a license. I am not keen on doing that since this is just a home lab.
03-25-2012 12:40 AM
For Virtulisation we only support vmware. You can either use MCS boxs or use Vmware.
regards
Ronak Patel
Please rate helpful posts.
03-25-2012 02:11 PM
The VMware server solution is a free platform.
03-25-2012 08:04 PM
You can download ESXi4 from below link
Ronak patel
03-26-2012 03:17 AM
You can run it on VMWare player but would recommended as per Ronak's post, ESXi on a dedicated which you can run for free (or full featured for 60 days) which is limited to the amount of CPU cores (6 from memory and the amount of ram).
But hardware is cheap you can run quite a lot even on an i5 processor and 16g RAM, thin provision. Just make sure you have an Intel CPU as well.
There are ways of using Sun's virtualbox to emulate VMWare hardware have done it but ESXi allows you to reserve the lower and higher limits of your CPU and RAM resources .
Heath
04-03-2012 03:35 PM
All very great guys. Thanks so much. The VMware playing was the one I really needed.
Cisco forum; always helpful.
Cheers guys
