ATA 187 Compatibility with CUCM 7.1(3)
Morning all,
I understand the Cisco ATA 187 analogue adaptor is only compatible with CUCM 7.1(5)+
Has anyone managed to upload the firmware to CUCM 7.1(3) and successfully register the device?
If so, are there any performance considerations I should be aware of.
Thank you
Jamie
Payal Bhaduri
The ATA 187 usually does not work with the cucm 7.1.3 in most cases that i have seen. There is no option in cucm 7.1.3 to add the ata 187 manually.
