Auto Attendant
nshoe18
I need to setup Unity and or CallManager for Auto-attendant functionality instead of a live operator. Can someone please provide some direction?
9 Replies 9
josequiros
If i understand you want to install Cisco Auto-Attendant for CallManager.
if you have 4.X version of callmanager you have to install the CRA program. you will find it on the CD "Extendent services"
A good place for Unity auto attendant functionality is this document:
http://www.ciscounitytools.com/Applications/Audio%20Text%20Applications%20in%20Unity.doc
I have CallManager 5.0.4
I have been poking around but cannot find a download for the autoattendant.
you won't find a download for auto attendant with CCM 5.x coresident on the same server there is no linux based cra yet, so for your case you have to get another MCS!
hth
/majdi
phillip-wright
Did you ever get resolution to this issue? I can provide some assistance if you haven't.
Hi Phillip,
I have an autoattendant in place on my CCM 4.01 but i need to change the way it handles the call flow. How can i modify the current aef file to come up with the new call flow.
Thank you for you assistance.
RA
Two things I need to know before going forward.
1)Can you be a little more specfic as to what you are trying to accomplish? (perhaps post a flow chart.)
2)How are you using the AA is it via a b-acd from Unity(Call Handler)or Standard IPCC?
1. aa.aef default script is loaded in my CISCO CRA. How do i customize this?
2. Im using CRA editor.
RA
