Avaya PBX as H323 Gateway in CUCM
ashishsurve
Level 4
Level 4
 I have setup where avaya G450 gateway is added as H323 gateway. My calling is working fine both way but the issue is its connecting with G711 instead of G729. I checked thw codec by pressing "?" button on my cisco 7942 phone.
This is what i see on avaya gateway.
LIST TRACE
time            data
20:22:58     Calling party trunk-group 9 member 1    cid 0x114
20:22:58     Calling Number & Name 4102 NO-CPName
20:22:58     active trunk-group 9 member 1    cid 0x114
20:22:58     dial 1100
20:22:58     ring station      1100 cid 0x114
20:22:58     G729 ss:off ps:20
             rgn:2 [10.144.246.229]:16794
             rgn:1 [10.34.179.251]:2052
20:22:58     xoip options: fax:Relay modem:off tty:US  uid:0x5001d
             xoip ip: [10.34.179.251]:2052
20:23:00     idle trunk-group 9 member 1    cid 0x114
20:23:42 TRACE COMPLETE trunk-group  9 cid 0x0
Kindly advise!
Chris Deren
What is the region configured on the GW and the Cisco phone? What codec is defined between those regions? Define the regions to use G729 between each other and ensure Avaya can support it and that should be it.
Chris
Suresh Hudda
Dear,
I think You should add a sip trunk pointing to G450 gateway instead of adding itself as H323 gateway in cucm. And for G729 calls you should have transcoder/pvdm on Cisco router and that should be register on cucm.
Suresh
Chris Deren
Chris
yes i checked the region and it was resolved. Thank for putting it in right direction.
