06-08-2016 05:09 AM - edited 03-19-2019 11:12 AM
We have purchased new BE6KS. I don't find much document to configure it but found some basic configuration examples. The box came with 3 Interfaces in Router and a module UCS-E160D-M2/K9 .In all examples i found router interfaces are using for communicating with VmWare ESXi and Telephony application installed in it. I wonder for what purpose the UCS-E160D-M2/K9 Interfaces G2 and G3. How can I use it dedicated for ESXi and VMs installed in it.
5 VMs found in ESXi. CUCM, CUC, IM&P, Paging, and Cisco Prime Provisioning. Will BE6KS will support Cisco Prime Deployment? If then how can I get Prime Deployment OVA?
Thanks for support
06-08-2016 05:25 AM
Unlike BE6000M and BE6000H, the BE6000S does not support any other application apart from the five that come preinstalled.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/data_sheet_c78-717454.html
As per the datasheet "BE6000S: Supports five fixed collaboration applications in a single integrated router/gateway/virtualized blade server platform; maximum capacity of 150 users and 300 devices."
For installation related details you can refer the following posts
https://supportforums.cisco.com/discussion/12560781/be6ks-implementation-questions
https://supportforums.cisco.com/discussion/12619206/be6ks-installation
Manish
06-09-2016 04:19 PM
Thanks Manish for your response.
I started installation of applications. Deleted preconfigured once and started installing new apps. IN router I created a subinterface for voice network and all servers including Vmware and CIMC belongs to that subnet. Now these traffic is passing through gigabit 1/0 interface. How can I use GE2 and GE3 interfaces of the module for Voice Application traffic?
