05-08-2024 12:51 AM - edited 05-08-2024 01:00 AM
Dear Experts,
i have a situation where i need to unblock the incoming calls from outside ( PSTN ) to some DID numbers which are NOT in sequence and range. So, i created a translation pattern of " ! " and UNBLOCKED ALL , then i create a translation pattern of a single DID number and BLOCK it . good working ..
But the problem is i have 21000 thousand active DID number in diffirent range and different sequence . i fear i may end up with thousand of unblock translation pattern. As an Example : Range: 456XXXX ,, i need to unblock 4561089 ,,4568699 ,,4567122 etc..
iam NOT using voice gateway here..
iam looking for any alternative way or any third party software or any idea .
05-08-2024 02:28 AM
This might be a silly question, but why are you blocking calls in general to your DIDs? Doesn't that defeat the whole purpose of having a Direct Inward Dial number assigned? If you could clarify the use case you have we might better be able to provide you help on this.
05-08-2024 05:57 AM
If you are not using a voice gateway, what is the incoming connection?
If you have a SIP Trunk on a router, you may be able to use an e164-pattern-map with a list of the 'allowed' ranges and numbers along with an "incoming called e164-pattern-map" dial peer. You can have up to 1000 entries in the config for an e164-pattern-map, or up to 5000 if you refer to a text file in flash. (Those numbers may have changed since the last time I looked.)
If you have a SIP Trunk to another call system, I wonder if it might be possible to use a Normalization Script to modify 'blocked' numbers to something specific and have an inbound translation pattern that drops those numbers. That idea is off the top of my head and I've not tried it, so I don't know if that is a viable option.
Maren
05-09-2024 07:11 AM
As I read this, I feel less clear on your environment and what you are trying to accomplish. Is your CUCM exposed directly to the internet and you are trying to prevent toll fraud? If not, it is hard for the people in the community to assist you without more details about what your are trying to accomplish and all the components in your environment (like how it gets its PSTN access).
