Blocking long distance calls while allowing local area codes
Daniel Isham
Level 4
Level 4
I am currently designing a dial plan with the line/device approach. I am able to block long distance calls but I want to allow calls to 3 area codes that are considered local dialing. You have to dial 1 plus the area code to perform the calls for the local calls. What is the best way to handle this since the local area codes route pattern overlaps with the blocked translation pattern of the blocked long distance calling?
IE)
Translation Pattern
9.1[2-9]XX[2-9]XXXXXX - PT_Blocked_LD
Route Pattern
9.1[555]XX[2-9]XXXXXX - PT_Allowed_Local
CSS_Line_Local
     PT_Blocked_LD
     PT_Blocked_International
     PT_Blocked_Fraud
Adding the PT_Allowed_Local partition to the CSS_Line_Local CSS doesn't allow the 555-XXX-XXXX call to go through.
Thanks for any help you guys (or gals) can provide!
Dan
P.S - CUCM v9.1
Chris Deren
Build explicit area code route patterns or route filter assigned to single route pattern.  Assume the first you would have:
area codes: 555, 556, 557
Blocking Pattern
9.1555[2-9]XXXXXX - PT_Blocked_Local
9.1556[2-9]XXXXXX - PT_Blocked_Local
9.1557[2-9]XXXXXX - PT_Blocked_Local
Route Pattern
9.1555[2-9]XXXXXX - PT_Allowed_Local
9.1556[2-9]XXXXXX - PT_Allowed_Local
9.1557[2-9]XXXXXX - PT_Allowed_Local
Notice the blocking patterns are in Local block partition as those should be only blocked if user is restricted to internal calling, by having the routing patterns define more explicitly than the 9.1[2-9]XX[2-9]XXXXXX Block_LD pattern you will archive your requirement.
HTH,
Chris
Chris Deren
Blocking Pattern
Route Pattern
HTH,
Chris
Daniel Isham
Level 4
Level 4
For some reason after I retried my route patterns and translation patterns in terms of what I was trying to achieve originally, it seems to work now. I might have set one of the fields wrong the first time I did it but I was able to add the PT_Allowed_Local to the same CSS that has the blocking translation pattern.
Thanks for your assistance as always Chris. I'll accept your response as a nifty alternative
