Showing results forĀ
Search instead forĀ
Did you mean:Ā
Call forwording to Call Handller
omarahmed
hello
I have call handlledr configure on my CUC i need to forword the   Non-answer call to that handller i put the number of route pattern in secation no answer prword but not working even i add Forwording & Routing  rule in cuc but still not working
6 Replies 6
Non answer call from where ?
what are your trying to achieve itā€™s not clear..
Response Signature
if im not answer the call from my phone i need to forword to call handdler
You need to forward it to a CTI Route Point with the same DN of the call handler and with Forward All to VoiceMail option selected.
What happens now when you call your Phone and you don't answer?
Please let us know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
 i used Route pattern insted off CTI Route point
Can you please elaborate more whatā€™s the expected behavior?
Carlo
thanks all i find the issue it from routing forword rule
thanks all
