Calls answer to speaker when handset is picked up?
Justin Westover
Why would calls answer to speaker if the headset is picked up to take the call? So when a user receives a call, the user picks up the handset but the call is answered on the speaker phone? Auto Answer is not on. What could cause this?
Andrew Skelly
Level 7
Level 7
Could be a firmware issue.  What phone model are you using and what is the firmware version being used?
Please rate helpful posts by clicking the thumbs up!
Is this happening to one phone or all phones.
I have seen some TAC case and RMA was the solution. Please see with TAC and check if it is hardware problem.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Rob Huffman
Hi Justin,
This is almost certainly a hardware problem with the Hookswitch as Ronak nicely noted (+5). After deploying Cisco IP Phones for the last few years we (and many others) have found this to be the most common hardware problem. There is a "Best Practice" for cleaning the Hookswitch contacts (link below) that does work "sometimes" . Usually the phone has to be replaced/RMA'd.
If you don't have smartnet on the phone here are the parts to fix this
http://www.nascsars.com/products.asp?cat=1297
BestPractices for Cleaning and Troubleshooting Cisco IP Phone Hookswitch
From this interesting Tech note;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00801c0810.shtml
Cheers!
Rob
Ron-Schutte_2
hello Justin,
wondering if the HookSwitch issue was the cause of this problem ?
when picking up the handset the phone goes to speaker.
regards Ron
