Bookmark
Subscribe
3695
Calls fails to forward to voicemail
jack samuel
i have integrate CUC 10.5 and CUCM 10.5 successfully, I am able to send messages through phone, but when a no answer internal or no answer external is tick in call forward settings for DN it doesn't forward the call to voice mail i have specified 10 sec , after 10 sec ringing i get busy tone and the call ends.
Hi Jack,
Few quick points to check here;
* Correct voicemail profile is attached to DN.
* Call Forward CSS can see the hunt pilot or route pattern depends on call manager integration with unity (SCCP/SIP). Although I can see that "none" CSS is assigned to call forward hence either hunt pilot or route pattern must be in "none" partition.
* VM port CSS can see the DN partition in case of SCCP integration.
* VM pilot CSS can see the hunt pilot or route pattern partition.
* Cross verify other CSS/Partition dependency if any.
Other points also needs to be checked depends on SCCP/SIP integration.
Vivek
7 Replies 7
Vivek Batra
Should first verify whether call is even hitting CUC or not. Remote port status monitor tool will help in this.
Vivek
Thanks vivek,
the call is not hitting to CUC, i don't see any call hits in remote port status monitor.Now what will be my next step to check where things are missing.
thanks
Hi Jack,
Could you make call forward unconditional/all work or it's also not working?
Vivek
Dear Vivek,
Attached is the file for call forward unconditional/ configured still the situation same.
thanks
Hi Jack,
Vivek
Dear Vivek,
Thanks for the chain of reply.
I missed the hunt pilot number from the drop down box  in the voice mail profile, once i selected the hunt pilot , the calls reached to the users voicemail profile.
Glad to know you could fixed it.
Vivek
