Showing results forĀ
Search instead forĀ
Did you mean:Ā
cBarge
johnwatson
Hellow guys ,
Can someone help me in why the get failed to setup barge in my cisco cme setup ?cme configuration
7 Replies 7
Moving this post to the Collaboration area where it is likely to get a better response/visibility.
 your dspfarm profile 1 is turned OFF. Barging is a type of conference call. Turn on the dspfarm profile 1 and try.
Response Signature
I turn it on by "no shutdown" and I still get failed to setup barge
Here is the new configuration CME Configuration
I am concerned by the command "sccp ccm 192.168.100.1 identifier 100 version 4.0"
Did you put the "version 4.0" in or did the system do that for you? It is an optional command in CUCME. The reason I ask is that the way CUCM versions pre-version-7 interact with dsp resources, and the way that CUCM 7+ interacted with dsp resources is very different. And by putting in "version 4.0" you are indicating that you are working with CUCM (and not CUCME) and also that you are working with a VERY old version of CUCM besides.
Please run the command "show dspfarm profile 1" and "show dspfarm profile 3" to determine if the dspfarms are properly registered.
If not: Change that line to simply "sccp ccm 192.168.100.1 identifier 100" and leave the version off, or if it will not let you change the version to "version 7+"
You will need to shut down the dspfarms, the sccp ccm group, disassociate the 'associate ccm 100 priority 1', change the version, and the reverse the things you undid.
Let us know what you find.
Maren
Hi Maren,
I changed the version to 7.0 and I still get "failed to setup bagre" , also this what I get from show dspfarm profile 1 and show dspfarm profile 3
CME#show dspfarm profile 1
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Total Number of Resources Configured : 1
Total Number of Resources Available : 1
Total Number of Resources Out of Service : 0
Total Number of Resources Active : 0
Codec Configuration: num_of_codecs:4
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
CME#show dspfarm profile 3
Profile ID = 3, Service = CONFERENCING, Resource ID = 2
Total Number of Resources Configured : 2
Total Number of Resources Available : 2
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
With your phones and dsp resources being all SCCP, please turn on the following debugs and try a cBarge:
  • debug sccp events
  • debug dspfarm events
Maren
