Cisco Attendant Console Business Edition 9.0-Distribution Algorithms
Vaijanath Sonvane
If multiple attendant console operators are available, what are the different types of distribution algorithms (such as longest idle, circular) supported in CUBAC 9.0? how to define it?
VJ.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Jonathan Schulenberg
By default it will alert all operators simultaniously. If you enable Forced Delivery it will round-robin the delivery:
Forced Delivery—select to make the queue a forced delivery queue. This makes an enquiry call
from the CTI Port to the next attendant handset in a circular, round-robin pattern. Attendants receive calls in a specific order (determined by the order in which they log in), and after the last receives a call, the first receives the next one. Attendants are skipped if they are still busy on a previous call.
Please remember to rate helpful responses and identify helpful or correct answers.
Hi Johathan,
Thank you for your help.
VJ.
