Cisco Call Manager Upgrade from Ver 5.1.3 to Ver 8.6
Amit Sharma
Hi ,
My organization have 4 Subscribers and 1 publisher between 4 different sites. version of all call manager are 5.1.3. all are running on HP Proliant server.
I looking to upgrade to Version 8.6. Do I need to upgrade server hardware as well for upgrading latest version of call manager or I can use my old server ?
Amit Sharma
2 Accepted Solutions
Hi Amit
According to the guide
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
You hardware (DL380-G4) is only supported to version 7.1(5). For version 8, it is only supported as a bridge server which means you can use it to upgrade your system so that it can be loaded onto a newer server however you can't run CUCM 8.x on it.
HTH. Barry
I concur with Barry. Your HP server is Supported only for "bridged upgrade" to migrate to newer hardware. In a bridged upgrade, you upgrade to the specified Cisco Unified Communications Manager version, make a backup of your software configuration via the Disaster Recovery System utility, reinstall the Cisco Unified Communications Manager version on new hardware, and restore your software configuration from backup. This server is not supported for any other use with Cisco Unified Communications Manager other than this "bridged upgrade" procedure.
Pls rate the post if it helps.
GP.
BTW, are/were you working for Crowne Plaza in Ireland ? I knew one guy with same name from that org.
6 Replies 6
Gajanan Pande
As the exact HP server model number is not provided, check if you can find your server model at following link http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
If the server model is mentioned as supported under CUCM 8.6(x) , then you may continue using it else you would need new server.
GP.
Hi GP,
Thanks for your reply.
Please find below the hardware details of my old server. these details I get from Cisco call manager application.
Hardware Resources
Hardware platform type    7835H
The CPU type    Intel(R) Xeon(TM) CPU 3.40GHz
Memory    2048 Mbytes
Detailed Report
Machine_Type = XXXX
Model_Number =
Serial_Number = GB8637LRFE
Product_Name = ProLiant DL380 G4
BIOS_Version =
BIOS_Build_Level = P51
BIOS_Date = 04/26/2006
BIOS_Manufacturer = HP
BIOS_Language =
Number_Of_Enclosures =
Enclosure_Type.0 =
Processor_Slots = 2
Active_Processors = 1
Processor_Family.0 = Xeon
Processor_Speed_MHz.0 = 3400
Total_Enabled_Memory_Mb = 2048
ROM_Diagnostics_Build_Level =
Amit
Hi Amit
HTH. Barry
GP.
Hi Gajanan,
How are you, yes I am the same
Thanks for your reply. Where are you working these days. drop me an email at asharma@tifcohotels.ie.
Thanks again for your advice.
Amit
Thanks Amit for the nice rating. Sent you a private message, check your inbox on this portal.
Good Luck.
GP.
