Cisco CUBE modification of response code?
Clifford McGlamry
Customer is asking if we can modify a SIP response code.  Specifically, when the CUBE receives a 487 (busy) response, the customer is asking us to return a 503 to the other leg.
Is there a way to do this?
Have a look at this url, it should have some information about what you ask about.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-condl-header.pdf
Response Signature
Interesting.  I'll have to lab this up.  Not sure if it will work as I'm trying to change the response code number itself, but it's worth a try.
