Cisco IM and Presence 10.5.1 Ova Deployment Error
Mazzy Star
We have a BE6000, we have successfully setup the CUCM 10.5 and Paging Server 9.0.1, But we're having trouble on the fresh re-installation of IM and Presence 10.5.1 when we're deploying its OVA. The system calls for a Halt during 2:45 remaining hours for Installation. Please see attached file for the error encountered.
stavropouloss
Hello everyone.
Since I had the same issue, what I did to fix it was to delete the IM&P server from System > Server section and add it back again when the re-installation script notified me that this was not the first node in the cluster. After that it passed through the db installation (it took a while though I thought it would fail again) to the presence component installation. It looks like this is only happening when you try to re-install the IM&P after you have done it once and put the server in the cluster already one time (like deleting the VM and creating a new one).
23 Replies 23
Terry Cheema
How many servers are already running on your BE server and is it a high or medium density server?  Just double check you are not exceeding the number of applications allowed on your server?
Also whats the OVA template you are using?
Normally this kind of error points a wrong OVA/unsupported hardware, but could be anything a Bug or any other issue.
Did you also try to delete and deploy a fresh template and see if it makes any difference?
-Terry
Please rate all helpful posts
Hi Terry,
We have a BE6K -H, and we have only 2 Application Servers Running : CUCM and Paging Server and the 3rd will be the IM and Presence supposedly.
Here's the Ova that we are using:
cucm_im_p_10.5_vmv8_v1.0.ova
and the Bootable ISO:
Bootable_UCSInstall_CUP_10.5.1.10000-9.sgn
-Mazzy
Hardware look good. Both the OVA and Bootable image looks good as well. But still can you try using this latest available OVA from Cisco website:
Ref: https://software.cisco.com/download/release.html?mdfid=286269517&flowid=50462&softwareid=283757588&release=10.5&relind=AVAILABLE&rellifecycle=&reltype=latest
Try deleting the previous OVA and deploy a fresh OVA, the latest version as per above and see how it goes.
-Terry
Thanks Terry, We'll try that OVA later.
Hi Terry,
We tried the new OVA, but it still didn't push thru with the installation, same error still.
Can you confirm you are adding this server to the CUCM before proceeding with installation. review the pre-reqs if you are missing anything:
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/10_0_1/CUCM_BK_I95AD2FE_00_installing-cucm-100/CUCM_BK_I95AD2FE_00_installing-cucm-100_chapter_011.html
Perform pre-installation tasks for IM and Presence nodes
You must complete the following pre-installation tasks before you begin to install the IM and Presence software.
Procedure
    Step 1  Ensure that the Cisco Unified Communications Manager and IM and Presence software versions are compatible.
    Step 2  Gather all the information you need to complete the installation and configuration of the IM and Presence software.
    Step 3  For every node in your cluster, create virtual machines using the Virtual Server Template (OVA file) recommended for your current release.
    Different OVA files are available; choose the correct OVA file based on the environment in which you are deploying Cisco Unified Communications Manager.
    Step 4  Configure subscriber nodes on the publisher node before you install a subscriber node. From Cisco Unified CM Administration on the publisher node, choose System > Server and configure the IP address for the subscriber nodes. For more information, see the Cisco Unified Communications Manager Administration Guide.
    Step 5  Ensure that the IM and Presence server has network access to the Unified Communications Manager publisher server.
    You can ping Unified Communications Manager from other servers.
    Step 6  Ensure that you turn on the Cisco AXL Web Service on the associated Unified Communications Manager server.
    Select Tools > Service Activation in Cisco Unified Serviceability.
    Step 7  If you use DNS, ensure that you have configured the hostname of the new IM and Presence server on the DNS server and that the DNS server can resolve the hostname of the Unified Communications Manager publisher server and of other IM and Presence servers (if any).
    Caution
    Cisco recommends that you use the same DNS servers between IM and Presence and Unified Communications Manager. If you use different DNS servers, it is likely to cause abnormal system behavior. Both Unified Communications Manager and IM and Presence must either use or not use DNS because Cisco does not support mixed-mode deployments. If you are using the multinode feature in IM and Presence, see the Deployment Guide forIM and Presence Service on Cisco Unified Communications Manager for DNS configuration options.
    DNS and Domain config passed the test... hmmm...
    We'll try to make a fresh install of the CUCM, maybe it's seeing the old IM and Presence registration on the CUCM (because we are making a fresh re-install of the Presence)   Just maybe...
    We're in the process of re-installing the CUCM,
    but we managed to get these dumps with one last try on Installing the CUP (IMPS)
    03/27/2015 15:15:27 IPM| item 7: shell-script 0 bytes (2.007 secs.)|<LVL::Info>
    03/27/2015 15:15:27 IPM|Execute shell command "/usr/local/cm/script/cm-dbl-install install
    PostInstall 10.5.1.10000-9 10.5.1.10000-9 /usr/local/cm/ /usr/local/cm/
    /common/log/install/capture.txt "|<LVL::Debug>
    03/27/2015 15:35:36 IPM|Internal Error, File:ipm.c:2011, Function:
    ipmReadNormalizedInputLine(), "/usr/local/cm/script/cm-dbl-install install PostInstall
    10.5.1.10000-9 10.5.1.10000-9 /usr/local/cm/ /usr/local/cm/ /common/log/install/capture.txt "
    failed (1)|<LVL::Critical>
    03/27/2015 15:35:38 IPM| end-of-session "Installing database component": 1692.644 secs.|
    <LVL::Info>
    03/27/2015 15:35:38 IPM|Close progress meter "Component Install"|<LVL::Info>
    03/27/2015 15:35:38 component_install|Writing database into
    /common/log/install/component_failed.xml file.|<LVL::Info>
    03/27/2015 15:35:38 component_install|/common/log/install/component_failed.xml created :
    0|<LVL::Info>
    ! some irrelevant data omitted
    DEBUG: <--|<LVL::Debug>
    03/27/2015 15:35:38 component_install|File:/opt/cisco/install/bin/component_install:807,
    Function: exec_progmeter(), /opt/cisco/install/bin/progmeter failed (1)|<LVL::Error>
    03/27/2015 15:35:38 appmanager.sh|Internal Error,
    File:/usr/local/bin/base_scripts/appmanager.sh:151, Function: install(), failed to install
    infrastructure_post components|<LVL::Critical>
    03/27/2015 15:35:38 post_install|File:/opt/cisco/install/bin/post_install:961, Function:
    install_applications(), /usr/local/bin/base_scripts/appmanager.sh -install failed (1)|<LVL::Error>
    03/27/2015 15:35:38 post_install|Exiting with result 1|<LVL::Info>
    Jaime Valencia
    Can you run this on your CUCM PUB and post the results
    run sql select userid,enablecups from enduser where enablecups='t'
    run sql select count(*) from enduser where enablecups='t'
    java
    if this helps, please rate
    Hi Jaime,
    Attached is the result.
    OK, if you had any users configured before the actual server was installed, it could cause that problem, seems is not your case.
    java
    <LVL::Info>
    0|<LVL::Info>
    <LVL::Info>
    0|<LVL::Info>
