06-14-2011 06:17 AM - edited 03-19-2019 03:06 AM
HI,
Want to use Cisco IP communicator 8.6.1.0.1 as my primary phone. I shut down my computer eveynight which means IP communicator is no longer registered with Call Manager. Is there a way to configure device or Cal Manger so that when my pc is off all calls to my extension get diverted through to my voice mail. thanks,
We have Cisco Unifeid Call Manger 6.1.3
Voice mail installed - AVST
Solved! Go to Solution.
06-14-2011 06:41 AM
HI Simon,
You should be able to use;
Call Forward Unregistered - checkbox to VM
This is set on the DN config page.
Cheers!
Rob
06-14-2011 06:41 AM
HI Simon,
Cheers!
Rob
06-14-2011 07:24 AM
great - thanks for the onfo
