Cisco IPICS AND Motorola MTR 3000
Hi everybody ,
I have a Cisco IPICS  and I want to communicate with My radio station.
My Radio Controller is Motorola MTR 3000. I have My LMR RMS Router Configure and integarte int My Cisco IPICS.
Actually my issue its that i don't know how to configure Motorola MTR 3000  E&m Port .
Did  Some already configure Cisco IPICS with Motorola MTR 3000?
your annwser will be helpfull
12 Replies 12
Radim Mutina
Hi Boris,
did you check SRND guide please ? There is chapter about LMR gateway interfacing and configuration.
http://www.cisco.com/c/en/us/td/docs/interoperability_systems/c_ipics/471/design/guide/sr471/sr471lmr.html
Basically, you have to find MIC, SPEAKER, PTT outputs/inputs on your radio, if you want to communicate through analog E&M card.
Radim
Hi Radim ,
Thanks for you answer and sorry cause i am replying late .
Actually de issue is that i can not see the E&m Port on the Motorolla MTR3000 .
I have a MIC card on the front of the MTR3000 could i use that as E&m Port ?
Thx
Hi Boris,
I'm afraid MTR3000 doesn't have E&M port. I don't know radio's with E&M ports - it doesn't mean any such radios doesn't exists :-)
I found MTR3000 service manual for you. There are described front/back panel connectors.
http://www.dhcom.fr/notices/Notice_EN_%20MTR3000_Install_and_User_Manual_DHCOM.pdf
You can't simply put straight RJ cable between E&M VIC port and MIC port on the MTR.
Fortunately it looks that  guys in Motorola prepared necessary input/outputs on J7 connector.
Look at page 2-21. You can find there TX/RX audio pins, PTT pins.
I think you should look some radio guy nearby you, he can help you with E&M to MTR cable creation. Or, try to contact networkedradio as sadiqyusuf  wrote - in case you're not familiar with cable creation.
Radim
Radim Mutina
Just one note, maybe it will be helpful too. I attached simple schematics of the cable what I'm using to connect to analog radios (VHF/UHF).
Radim
sadiqyusuf
first you need to get an interface cable from this site: http://networkedradio.com/ then the configuration, you can find a step by step from the SRND guide doc.
i have a GM-300 radio with the interface cable to the E&M port, i've done the config step by step but still can't establish a call between the IP-phones and the radio.
Hi sadiqyusuf,
Did you try following test - dial into SIP phone integrated into IDC, then create Patch with Radio Channel or VTG (with your GM-300 radio) ? Or you were using IPICS phone service ?
Could you please describe what kind of tests did you do ?
Radim
yes i have two 7975 phone on a CUCM, integrated with the IPICS server, i have a cable connecting  the GM300 radio to the E&M port on my RMS.
i can push a call from the DC to the IPphones but when i patch the radio channel, no signal.
Could you please describe more in detail what you mean with "no signal" ? In which direction ?
If you do PTT on IDC, could you speak to radio ? Did you hear signal from radio on IDC  ?
Things to verify:
1. LMR gateway config
2. cable between radio and gateway
3. multicast routing
Could you please post your LMR gateway config here ?
I'm also adding some useful commands to check E&M/radio connection.
LMR_gateway#test voice port 0/2/0 inject-tone network 1000
LMR_gateway#test voice port 0/2/0 inject-tone network disable
- this will verify if your LMR gateway is sending multicast in case there is an audio-in signal at E&M
LMR_gateway#test voice port 0/2/0 inject-tone local  1000
LMR_gateway#test voice port 0/2/0 relay e-lead on        ! E-lead is connected to PTT, so we do PTT ON
LMR_gateway#test voice port 0/2/0 relay e-lead disable  ! PTT OFF
LMR_gateway#test voice port 0/2/0 inject-tone local disable
You can use also debug vpm all to check LMR signaling at E&M.
Radim
i can send voice signal from the IDC to the phones, but i can't reach radio. i will try the commands......find attached the config on my RMS.
After quick look at your config, I can't see ip pim sparse-dense-mode commands in Vif1 and Gi0/0 interfaces.
Hello Radim,
thanks for your observation, i have added the ip pim sparse-dense-mode commands in Vif1 and Gi0/0 interfaces. i also want to know before i test with the added config.........where am i suppose to configure multicast? on my access switch or the RMS. thank you.
JOHN CONNOLLY
Are you using a donor radio to access the channel you are using?  what model radio?
